is 1060 3gb a better deal than rx470 if its cheaper?
Solved by RollinLower,
keep in mind that the 3GB model of the 1060 is also a little less powerfull than the full 6GB model. that being said, i also recommend the 470. 3GB VRAM is really just not enough anymore these days, as some games like GTA V and Rise of the Tomb Raider all use more already!
it should definitely be enough if you are only going to be playing older titles though, but for newer stuff 4GB is the standard these days.
