Silent and relatively cheap case fan.
jamesfindlay3
Hello, I am looking for some new case fans preferably 140mm (i think this is best correct me if I'm wrong) what would you say to be the best priced and most reliable silent oriented case fan. It Is for a micro ATX case and I don't want to be spending too much money. What would your suggestions be, at the moment I am thinking be-quiet but they don't have the best reviews and are a bit pricey. Thanks!
Just now, Electronics Wizardy said:
is there a reason why you need anouter fan?
normally the fans included enough are fine, esp if your on a budget
The case i am getting only comes with the one fan and i don't think this will be sufficient plus it needs to be quiet as i live in a busy household and the people around me hate too much noise.
Fractal design R3.
3 minutes ago, jamesfindlay3 said:
Yeah nice and clean case i put it down as a maybe, thanks!
Not the Define R3 Case, the Silent Series R3 fan :P
Some companies that I know make great, cheap fans are Phanteks, Fractal Design and CRYORIG. I have personal experience with the CRYORIG XF140 (140mm airflow-optimised fan) as I have one strapped to my CPU cooler. It's inaudible, and dirt cheap.
Other systems I've built:
I see and yeah i looked at cryorig i will be getting the m9i cpu cooler but i didn't realise they made separate fans haha, thanks. And i'll have a look at those brands and see what looks best. Thanks!
What are your specs and where are you planning to put the fans?
Where are you shopping/located?
