How often do i need to clean my PC?
Solved by minibois,
1. depends on how dusty it is in your home and the amount of fans you have (and just general hotness of stuff in your PC). every year a big clean up and every couple months a small clean up is a good habit.
2. just clean it regularly, there is not really different ways to clean fans you can get canned air or a data vac, but it's not necessary.
3. dust build where intake is, so at fans mostly. It can also fall on stuff where there is no airflow, like on HDD's.
4. dust filters.
