Good god never buy a U1 rack server that isn't cable managed well from the factory. No offense HPE but its taken well over two hours to get this far. I hate this kind of cable management, it doesn't even look that good, this is a nightmare. So tiny, so many cables, so little room.
Yours faithfully
https://linustechtips.com/topic/676060-i-now-hate-cable-management/
2 minutes ago, Dutch-stoner said:
Why not drill some holes, to run the cables below the rack? Or will that cause problems...
It's a U1 chassis. At most he has about 0mm under the bottom. Unless you mean straight through the chassis.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
6 minutes ago, NumLock21 said:
Your zip ties is suppose to be RGB not RGBBW (red, green, blue, black, white) :P
I was colour coding them (Red for SAS, yellow for fans, buttons/inicators, green for USB, blue for PSU/power) but I ran out of blue ones.
Yours faithfully
That isn't really an option, the server wouldn't sit level, would fuck it up in the rack and possible let air out and impact cooling.
Yours faithfully
12 minutes ago, xgn said:
This is cables you're not even going to see. I never understood why people make a big deal out of that. It looks good enough already in my opinion.
the fans are tiny and the noise from the cables flapping in the air was annoying.
It also allowed dust to build up in the corners and under them.
Yours faithfully
If it helps I usually use extensions to run cables along the sides rather than next to the fans.
well, fuck, the server is claiming a fan is missing or failed (maybe the connector got knocked loose) BUT FUCK, THE FANS WENT EVEN LOUDER THAN WHILE ON POST, I THOUGHT THAT WAS 100% BUT IT ISN'T, FAIL SAFE MODE IS EVEN LOUDER! Oh the irony.
Yours faithfully
I went and recorded the server booting, and the missing fan response, which was nothing short of ear pounding, The video is still processing, it'll be a minute or two more, actually I'll wait until it's live to hit submit.
Yours faithfully
It sounds wonderful with 5.1 speaker fill. Did you throw a Yu-gi-oh card over the edge?
No, it was some label off a decoration for spooky night. That was to show the amount of air moving through this thing.
Yours faithfully
2 hours ago, SpaceGhostC2C said:
If you are not satisfied with it, you don't want cable management: you want invisible cables :P
I am actually really happy with how it looks now, it was just AMAZINGLY harder than even a cheapy case.
Yours faithfully
