Cable Combs for Ensourced Paracord Cable Extensions
Solved by W-L,
3 minutes ago, CRA5HMAN said:The dude from Ensourced said they are 16 gauge wire. I am guessing the 18AWG is 18 gauge wire? Would I be able to use the CableMod cable combs?
Yes 18AWG would be 18gauge, and that would also explain why the MNPC billet combs will not work as they are a larger diameter. Since it's 16AWG it will be tough to find compatible cable combs unless it is something ensource makes specifically for their cables since it's larger.
