Posted September 28, 2016 I am upgrading to a 144hz 24inch monitor and I was wondering if someone could help me decide between the following 3 as they are in my price range. If you can explain to me why the monitor you pick is better that would be great. -Asus VG248QE -BenQ XL2411Z -Aoc G2460P Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 28, 2016 They all have pretty much the same specs. Pick either the cheapest or the one you like the most. I'm presonally using 3 Asus VQ248QE Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 28, 2016 The BenQ XL2411Z has the lowest contrast ratio of the three so I'd scratch off that one. Aoc G2460PG has G-Sync while Asus VG248QE does not if that's something you want. In the end my vote is for the Asus as well since G-Sync is kinda overrated since Nvida's new Fast Sync can work with any monitor. In addition to the fact that I don't think you could ever use G-Sync panel with an AMD graphics card if ya ever got one. Ryzen 5 1500X @ 3.9GHz On 1.3625V | MSI B350M Gaming Pro | 16GB G.Skill Ripjaws V DDR4 3200MHz | 3GB MSI GTX 1060 Gaming X 2063MHz Core 9408MHz Mem | EVGA G2 550W | 250GB Samsung 850 EVO | Windows 10 Home 64-bit Version 1903 (Build 18362.295) | MasterCase Pro 3 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 28, 2016 Author I'm thinking of going for the sox monitor as I save 60 bucks if you compare the price from the acres price to the aoc Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
