How to remove 3-pin wall socket?
Sorry for posting such a topic on Linus Tech Tips even though its for non-tech related posts (No other sites came across my mind and I :x the great community here). So, how do I remove the 2 tiny circular caps? The caps are preventing me from accessing the screws underneath them. I've got a replacement cover since this one is faulty. (I can't turn off the heater)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/666380-how-to-remove-3-pin-wall-socket/
8 hours ago, SageOfSpice said:
Look like they should just pop off. Jimmy a screwdriver under one.
Probably turn the power off first though.
Yeah @Freezanator you just pry the caps off with a flat-head screwdriver. Just try to use one of the smaller sizes, as the thinner head will make it easier to get under there.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
just pry them off, alternativly superglue something to them and pull them off but that requires time and effort :P
Builds:
Thanks everyone here for your replies. I managed to successfully remove the caps and replace the wall socket. I actually forgot to turn off the power and got a little shock when touching one of the wires inside xD. It just sent a vibration through my arm and felt a little ticklish. Once again, thanks for everyone for taking your time to reply!
My Daily Driver:
Just so you know, power from the wall can kill you if it strikes you the wrong way - Most outlets can deliver over 1500 Watts of electricity (Standard US is 120V at 15A = 1800W).
So next time remember to shut off the breaker :P
Agreed but who hasn't been electrocuted a little bit lol
Yeah but still, common sense says that can kill you :P
What do you mean 'in the wrong way'?
My Daily Driver:
Well, how the electricity flows through your body directly relates to the risk associated with it. Basically, anything flowing from one side to the other (Eg: Left hand to right hand), has a very strong chance of crossing through the heart. If that happens, your heart has a high chance of failure.
So if one contact point was your knee, and the other was your toe, for example, then that's not super dangerous.
Same with a single finger, since the electricity is mostly just going to travel through the finger tip. Electricity likes to take the path of least resistance. Unfortunately, if the contact points are on either side of your body, that path usually takes it through the chest cavity.
It also depends on the physical conditions around - if you're wet, if anything you're wearing might make things worse, etc.
