Best case under U.S $100 with good cable management
Solved by SteveGrabowski0,
Fractal Define S is indeed about the cleanest looking case I have ever seen since you mount your 3.5" drives behind the motherboard tray. I have the Phanteks Enthoo Pro and that case is awesome for cable management also: tons of places in back to tie cables up with the included velcro straps. I chose the Enthoo Pro over the Define S since I live in hot ass Texas and wanted active cooling to my mechanical drives. But if you don't need to worry about hard drive temps the Define S is about the best designed case I have ever seen. It would be perfect if it had a top dust filter. As it is I'd just cover the top with the moduvents though since you can get a ton of airflow just from the front 140mm fans and the rear fan.
