Linus double or triple Internet speed video
bobfreeman
In the video Linus shows a way to connect 2 Internet networks together with a box to increase his Internet speed. I was wondering if there was a max speed to that. Would I be able to get a second gigabit fiber connection and bond them together for 2 gigabit speeds?
Depens of what your doing.
You normally can't download one file twice as fast, but you can download 2 files twice as fast.
That video was for LAN file transferrs with SMB3 on windows 2012/8 or newer
If you refer to this video it's for internal networks not for the internet.
The new one on vessel
He's referring to another video. On Vessel, not on YouTube yet.
Other systems I've built:
Fk maybe i should start using Vessel again :D
To answer your question, Edzel tweeted about this and the response was:
1: iTel's bonding service only supports bonding connections with speeds lower than 900mbit/s
2: Even if they could bond gigabit connections the bonding cost would be massive. Like, multiple thousands of dollars per month.
So it would be a better choice to just get a 2 gigabit service for $300 a month? I was thinking that I could save $100 a month by getting 2 one gigabit plans for $100 a month each
The service in the video can't bind gigabit connections, so you'd have to shell out for a 2 gigabit connection if you wanted that speed.
I'm thinking of bonding my 0.45MB/s  with another so I can at least achieve one meg down :'(
