what is vga standard graphic card adapter
Solved by BlueChinchillaEatingDorito,
8 minutes ago, L0str31 said:i got windows vista and the manuefactuer the languege is netherland and i don know how fix anything inside and i did yester a factory reset to see is i can change the languege but i can what is standard vga graphic adpater how to download where i can find the driver any help u guys can do
Standard VGA Graphics Adapter is the most generic Graphics driver to get most GPUs running in Windows. You will need to go to Nvidia's website or AMD's website (depending on your GPU) and download the latest driver for your GPU.
