4 minutes ago, DaMonstah said:
ok. Thanks! Oh and Aytex, im probarly not going to be overclocking, so i won't need that
Change your CPU to the locked one then.
3 minutes ago, Verrierr said:
You mean locked one. Unlocked ones are for OC.
LMAO. Don't mind me. I'm not feeling well. :(
3 minutes ago, DaMonstah said:
ok, since im pretty new to pc building, whats the difference between a locked and unlocked cpu?
unlocked is when you can overclock the CPU and the locked is the opposite. You can't overclock it.
An locked CPU means a stock CPU. Unlocked means that you can boost it with overclocking.
Main Rig - Case: Fractal Design Pop Air XL Motherboard: Asus TUF B650 Plus WIFI CPU: AMD Ryzen 5 7600 RAM: Corsair Nautilus 240 RAM: Corsair Vengeance 16GB 3000MHz32GB Corsair Vengeance DDR5 6000MHz  SSD: 1 TB 1TB Samsung 990 Pro NVMe
HDD: 2TB WD Blue  GPU: Asus RTX4070 Dual Evo PSU: Corsair RM850X
Corsair 200R Front Bezel Mod
You can't overclock locked CPU by increasing multiplier (since it's locked obviously). You can however do a bclk overclock but you can't really predict how it goes honestly.
Then save some cash and buy the i7 6700
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
I would get this
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($319.99 @ B&H)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  ($14.99 @ Newegg)
Motherboard: Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard  ($99.60 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($38.88 @ OutletPC)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($63.99 @ SuperBiiz)
Storage: Hitachi 2TB 3.5" 7200RPM Internal Hard Drive  ($53.00 @ Amazon)
Video Card: Gigabyte GeForce GTX 1060 6GB WINDFORCE OC 6G Video Card  ($268.50 @ B&H)
Case: Corsair 200R ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.89 @ OutletPC)
Total: $1018.82
Generated by PCPartPicker 2016-08-25 10:29 EDT-0400
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Kind of wrong. As I said locked CPU means it's multiplier can't be changed but you can still do bclk overclock. There are a lot issues with that though since changing bclk impacts a lot of stuff in your rig. When gaming it's very ill advised to overclock with blck since it will very often result in stutters and other issues.
2 minutes ago, DaMonstah said:
This might be my final choice, https://pcpartpicker.com/user/DaMonstahh/saved/#view=KvYPxr
is everything good?
I've heard somewhere that seagate's desktop class drives are of poor quality but I have no idea if that's true to be honest (maybe I shouldn't repeat unverified info?). Also next time you have some cash on hand you might consider (depending on your workload) expanding your RAM.
1050 bucks is my budget, but when i have more money i could expand my Memory.
oh and will the graphics card fit in my case? i can't seem to find the dimesions
It should
is everything good?
This is a great PC... There's nothing to worry about!
38 minutes ago, DaMonstah said:
Hi i recently made a pc build on pcpartpicker.com but im not very sure if it is good for what i will do, recording games editing and rendering. Here's the list.
Thanks
I would definitly recommend the Cryorig C7 or H7, as the 212 Evo really doesn't live up to the hype. Also, unless you are doing some high end internet browsing, you don't really need to be getting a $70 wifi card.
