Why does CPU have 12V input?
Solved by samcool55,
12V comes in and gets turned down to the voltage required by the CPU by the CPU VRM.
The reason it uses 12V and not 5V is because 12V is also easy to work with and you can use lower amps to get the same wattage.
Also Vdroop is easier to handle at a higher voltage because you have more room to work with.
edit: the VRM is around the CPU and most mid/high-end boards have some form of cooling on it.
That's why you usually see heatsinks around the socket, it's cooling the VRM.
