Overwatch Connectivity Issues
Solved by marshmallowbam,
The only method i know if would be to buy a PCIE ethernet card. As for which one I have no idea, I have never encountered this issue before so I would look around on the forum for the best ethernet cards and do some research yourself on the subject. I just thought of one more method, not sure of how much help it may be in finding an underlying issue or solution but do you have an external wireless card you could plug in? if so try that to see if you get the same results. If you do it MAY be an issue with your router pushing you to the bottom of the list for signal.
