Posted August 7, 2016 Hello LTT Forum, I am planning on upgrading my pc. Currently running on: Core i5 4590 3.3GHz, 8gb ddr3 ram, 650w psu, 1080p monitor and other stuff but no GPU. Mostly used for gaming. I will buy either rx 480 or gtx 1060, and another 1080p monitor. There is no possibility of changing the card in the near future. so for me mainly gaming on 1 1080p monitor suggest a card supposing those 2 are at the same price point(suppose exactly same). No fanboying please, just clear facts and help me choose a card. Again suppose both cards are priced same. or if you guys have any better suggestion, do suggest but not 1070/1080 or fury (way out of my budget ) Thanks in advance Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 7, 2016 GTX 1060 is a bit more powerful so if they're the same price then get the 1060. |PSU Tier List /80 Plus Efficiency| PSU stuff if you need it. My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon || Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 7, 2016 If they cost the same, 1060 will give better performance. But if you want to have the ability upgrade to dual card later, the 480 is the only option Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
