PhysX + PCI-E lanes help
2 minutes ago, js_theking said:I need help with my new build. I currently already own a GTX 1080, and I was pretty much disappointed by the performance of my card in Mirror's Edge Catalyst. With everything maxed at 2k res out I was averaging 80 FPS while Doom was rock steady at 144MHz.
Quick question: what was your monitor again?
2 minutes ago, js_theking said:So my first question is, would adding let's say a GTX 1060 dedicated for PhysX really help?
Strong card + weak Physx car = Weak performance. Unfortunately, a slower PhysX card will actually slow you down rather than improve things.
3 minutes ago, js_theking said:If I add said card, how much PCI-E lanes would I really need? I'm planning to add an Intel 750 pro to my build.
Ah... you'll be fine. Don't worry about it.
4 minutes ago, js_theking said:Is 48 lanes even possible? I've seen the i7-6850k running up to 40 lanes. Would that bottleneck my 2 GPUs + Intel SSD setup?
No. And no.
