a 1080 for physX... really? like, shouldn't a GTX 750Ti be enough for that? :/
Skunkworks has always been basically the best you can get for money on the marked right now so 2 1080s + PhysX card it is :P
Builds:
Yes it would. But that would go against what skunkworks is about. The entire idea is to be one of the best PCs on the market which grows with the channel.
I thought he already settled on two 1080s? PhysX doesn't really have that much relevance now, does it?
13 minutes ago, Epmd612 said:
Skunkworks it getting an upgrade, the big question is, is two Gtx 1080's or two Gtx 1080's plus a PhysX card. Please go down below and vote away!
http://www.strawpoll.me/10865393
Thanks everybody!
- Ethan
None of those. AMD is the way to go.
My rigs:
NEW Ryzinator build:
CPU: AMD - Ryzen 9 3950X 8-Core Processor
Motherboard: Asus - PRIME X370-PRO ATX AM4
RAM: Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-2666 @ DDR4-3066
Storage: (3x) Samsung - 850 EVO-Series 500GB 2.5", Samsung - 960 EVO 250GB M.2-2280
PSU: Seasonic Prime TX-750
OS: Microsoft - Windows 10 Pro 64-bit
Additional fan: Noctua - NF-A14 PWM 82.5 CFM 140mm Fan
Case: Fractal Design - Define R5 (Black) ATX Mid Tower Case
GPU: ASUS Radeon RX 580 Dual OC 4GB
Display: MSI 27L Optix MAG272QP @ 165Hz
OLD Build (SOLD):
CPU: AMD FX-6100 Motherboard: ASRock 960GM/U3S3 FX (VRM overheating, don't buy) RAM: 8GB Kingston ValueRAM GPU: Onboard ATI Radeon 3000 Graphics Case: Corsair Obsidian 500D Storage: Hitachi HDS721010CLA332 1TB, 119GB SAMSUNG MMCRE28G5MXP-0VBH1 (SSD), 465GB Western Digital WDC WD5000AZRX-00L4HB0 (SATA)  PSU: Be quiet! - Straight Power 10 400 Watt Cooling: Cooler Master Hyper 212 EVO OS: Windows 10 Pro x64
Retro gaming build:
CPU: Intel Pentium 3 Coppermine @ 800MHz Motherboard: Asus P2B i440BX BIOS 1012 FSB: 133 MHz RAM: 1x 128MB Hynix PC133 SDR SDRAM GPU: ATi Radeon 9200 256MB AGP Case: Full Tower case (unbranded) Storage: CompactFlash card to IDE converter (16GB card) Sound Card: Aztech 2320 ISA Cooling: Stock heatsink fan OS: Windows 98 Second Edition
@JayzTwoCents I'm also going to go with a pair of GTX 1080 Classifieds for my personal build during the December holidays when the Fall semester is over :). Boy would two of those bad boys demolish 3D rendering, even 4K rendering in Nvidia Iray in 3ds Max, plus 4K gaming with settings cranked to full effect (BTW I am going to get an ROG Swift PG27AQ to go along with the upgrades! PB238Q will be used as secondary because it's still good). Not to mention I also plan on upgrading my RAM to 32GB of Klevv Cras 2133 MHz.
Next set of upgrades would be a case and custom-sleeved cables for the AX1200i. Does anyone know what case I am very confident I will jump to? :D
I personally think the 750 Ti would suffice for a PhysX card (assuming said game uses PhysX)
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
14 minutes ago, JJVGaming said:
Ik he says he is not getting a titan xp but he probably is going to get it anyway. He did this with the 980 and ended up getitng the titan x...
He won't put them in his personal build. He made that clear in the final episode of the Red Mist upgrade series.
RIGZ
STRONK COOLZ 9000
DESK TOIS
QUOTES
