Keep GTX 970 or upgrade to GTX 1070?
Nick92
Hi all,
Here's my system specs:
i7 6700 (non-k)
MSI H170A Gaming Pro Motherboard
MSI GTX 970 Gaming 4GB
Corsair Vengeance 16GB
SSD Samsung 850 EVO 250GB
Seasonic S12II 620W
Monitor: LG 24GM77 144Hz
I usually play esport games like Dota 2, CSGO, etc..., rarely play AAA games (don't have time for these). Does my rig need to be upgraded and will it handle for 2-3 more years? I just work and play games in 1080p only, I will consider to get 1440p in the future.
Please give me some of your recommendations. Thanks! :)
if you only play esport games there's little reason to buy a 1070.. maybe consider the 1060
for those games a 970 is more than enough. once you will upgrade to 1440p consider a 1070 again
Longboarders/ skaters message me!
I just came from a 1080p+GTX970 setup then recently upgraded monitor to 1440p.
Well as of my experience the 3.5+0.5GB Vram really affects perf @ 1440p.
So if you consider on getting a 1440p monitor then you might as well buy the 1070.
i9-9900K || MSI MPG Z390M GAMING EDGE AC || Gigabyte RTX 2080 Super Gaming OC || 16GBCorsair Vengeance LPX 3200Mhz || Samsung EVO 970 Plus Samsung 850 EVO 2TB + Crucial BX100 500GB + 4TB HGST NAS || Factal Design Define Mini C TG || Corsair RM750x || Corsair H100i Pro RGB || Acer Predator XB271HU
If u just play csgo, dota no it's not a good idea but for AAA game yes,
AMD - Ryzen 5 2600 3.4GHz 6-Core / Evga 1070ti ftw 2 8 gb/ MSI B450 tomawack / Stock cooler/ G.SKILL 16gb 3000mhz RGB / 860 evo 500 GB /  XL2411 144HZ  / Western digital blue 1 TB 7200 RPM/ Corsair 760T (white) |Window 10 pro
Csgo: a pentium G3258+ gtx 750TI can run at 200 fps (max)
@all: Thanks for your replies. But the thing is i'm using a 144Hz monitor, means that more things for 970 to process, and games these days require more powerful GPU. I know I'm a bit greedy but I want everything to be smooth in gaming and working. :)
Grab a 1070. 970 can't really do 1440p properly
16 minutes ago, Nick92 said:
Hi all,
i7 6700 (non-k)
Seasonic S12II 620W
I mean, if you play CSGO all of those Pro players usually put it on Very low settings so it doesn't matter. and Dota it doesn't have the best graphic in the market so no problem there. So yeah, keep it.
DESKTOP PC :
  CPU :RYZEN 5 2600/ GPU :MSI Ventus OC GTX 1660 Ti/ RAM :Team Elite 2x8/ PSU :Corsair CX650M/ HDD :Toshiba 2TB/ SSD :Adata XPG M.2 SATA 265GB/ COOLER :Be Quite 2x140mm / MOBO :Asus TUF B450 Gaming
LAPTOP :
  CPU :i7-4710HQ/ GPU :GTX 860M/ RAM :8GB OEM/ HDD :1 TB
PERIPHERALS :
  MOUSE :LOGITECH G502/ HEADSET :HyperX Cloud Alpha/ KEYBOARD :Logitech G Pro
POSSIBLE PC BUILD :
  PC PART LINK
970 SLI if you need more power.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
If you want to spend money on a new GPU, either take the 980Ti which sometimes is able for the price of under 400€ or take the 1070 which is more power efficient and costs about 500€. (At least where I live - Germany)
The 980Ti is about the performance of a 1080 FE so it would be a good deal, if you could get it at least 100€ less than the 1070.
You decide.
CPU: i7 6700K @ 4,8GHz
Cooler: EKL Alpenföhn Olymp
RAM: 2x8GB Corsair LPX 3200MHz
GPU: GTX 980 Ti 1540MHz with Rajintek Morpheus
MoBo: ASrock Z170 Extreme 4
HDD/SSD: Hitachi 1,5TB / Samsung EVO 500GB
PSU: beQuiet Straight Power 600W CM
Case: fractal Define S
You decide.
980ti isnt about the same as a founders 1080 at all mate. 1070 yes, 1080 no.
The 970 is right around the 10th best card you can get. There really isn't much incentive to upgrade to the 1070 from a 970. Until 4K games can be played @60fps or more, there is not much of a point to upgrade from generation to generation of graphics cards. If you had a 760 or older card, upgrading to a 1070 would make sense. I get over 100fps @1080p on BF4 type graphics games with my 970. Project Cars 110-120fps. It's still a very good card.
Just keep your card. If you want better framerates, lower the settings.
You'll want to buy a new gpu when your current gpu can't handle the games you played at the setting you want.
He fucking said he only plays Mobas. How about you actually read the OP before telling people to shell out £400 for no reason?
A 960 can play these games at 4K, a 970 will handle 1440p fine.
Pretty sure a 960 wont run this games at 4k. Guess you made a typing error.
No I didn't. It's not difficult to run League of Legends, Dota 2, CS:GO at 4K. Linus made a video of this with a 285, which is about the same level of performance as a 960.
Ultimately you should upgrade your GPU whenever you feel that it is no longer capable of delivering the framerates you want at the settings you'd like in the games that you play. Not because some 12 year old on the Internet who has no concept of money tells you to.
If I seem grumpy, it's because this kind of thing irritates me. This is why PC Gaming is really off-putting to people and has a reputation for being ridiculously expensive. Because people are recommending a GPU that costs nearly double the price of a console for playing fucking Mobas and Arena Shooters.
Wow, these are some of the worst responses I've ever seen. They didn't even read the post.
@Nick92keep your 970. There are zero reasons to upgrade if your mostly play e sport games that can be run on a potato and your 970 is still fine for AAA games.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
@all: thanks for all of your replies. Last question I want to ask is that how long can 970 handle?
What you mean is how long will your current system last without being to hold it's own on games (60fps). At least 2-3 years easily with the caliber of games you are playing 4 or 5 years. When people talk 1440p and 4K gaming, a different story but your 970 could easily run CS:GO at 144op and 4K easily with 60+ fps. I get 300fps (max fps CS:GO counter) with my 970 playing CS:GO @ 1080P.
Ok then, I'll keep it. Thank you. :)
An overclocked one is.
I mean there is really no point to, If I was you I would just wait till nivida makes a whole new line of GPUs
