Wi-Fi Cuts Out Every Few Minutes
Guest
My Wi-Fi keeps cutting out every few minutes. The Wi-Fi symbol still shows that I am connected but nothing works. Any help?
6 minutes ago, Slottr said:
Have you tried turning it off and on again?
yes many times
open cmd and type the "ping <routers ip (e.g 192.168.1.1)>"
If it get though with not problems do "ping 8.8.8.8"
if that comes back with errors it is your internet connection or if it is the first one it is the connection between you and the router. Tell me your result.
What are you looking for?
Sorry I'm a little late but i received no error messages.
scan your wifi and see how many WiFi hotspots do you get?
your router might be on a channel that is clashing with other routers
so you might need to change the channel
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
