Enthoo Luxe Fan Placement
Jacob Canale
Hey Guys!
What would be the best fan placement for the Enthoo Luxe? Number of  fans doesn't really matter, and im gonna be using the be quiet! Pure wings 2 (120mm and 140mm). Also using the H110i GTX (280mm).
Thanks!
i dont know i was about to buy one tonight and i find out they hardly sell them anywere and where they do its alot more expensive then it used to be, i think itmight be becasue the new temperd glass one coming out soon but i dont know when
1 minute ago, spartaman64 said:
noctua fans
Not to be rude, but I clearly stated what fans im using, and im using them for a good reason. They are cheap with good reviews. The noctua fans are overpriced and look quite ugly in my opinion.
then whats the question? if you already decided on what fans you are using
The question was what is the best fan PLACEMENT. As in where should i put them.
srry read replacement probably an intake configuration with the cooler either in the front or top and then a rear exhaust fan
just one exhaust?
just one exhaust?
its my philosophy of fan configuration have a bunch of intakes and then have the fan at the top rear be exhaust
This video is oriented to air cooled CPU. But key points remain. Best setup is to have close to neutral air pressure. That way you get best from both sides. Less dust than what negative would give, and more cooling performance than what positive has.
Personally I would go for 2x140mm at front and remove all HDD cages I wouldn't need. Then put rad as top exhaust and adjust fan speeds so that front fans run as fast as I can stand the noise of them. And lower rad fans so that temps stay at reasonable levels.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
instead of the 2 140 mm fans at front, do you think i could leave the 200mm one there?
Sure. 2x140mm wpuld bring more air in while being as noisy. If you remove atleast one of HDD cages, I think you are fine. I have 200mm fan at front with 1 empty slot between drives. That brings enough air for my taste, I'm not so worried over normal operation temps.
What are your specs?
2 minutes ago, Jacob Canale said:
Top h110i and bottom 140mm intake, 140mm for rear exhaust.
