The quietest case fans
Alesek
Go to solution Solved by WoodenMarker,
1 minute ago, Alesek said:
Well, Define S can fit 9 fans which I guess is not necessary. Plus opening the top of the case so he can put fans there is gonna take some of the sound proofing away.
What do you think about 3 - two front and one in the back?
That'd keep positive air pressure, noise to minimum I thinkand, hopefully enough airflow
Depending on the components and the noise level you're shooting for, it should be fine.
Hi, my friend wants me to help him make his pc quiet and he wants me to put there the quietest case fans. He has an older mobo which can only control the PWM fans all together (all fans always have to have the same speed). So I was thinking I would connect 2 super quiet fans to PSU (one front and one back) and for gaming (heavy load) I can set up for him Speedfan which would start other front fan if necessary.
So my question is... which are the quietest case fans we could use to connect to PSU?
Or is it better to use 3 pwm fans connected to mobo, set to the lowest rpm and increase rpm during higher load?
5900X
MSI MEG X570 Unify
32GB DDR4 Corsair Vengeance
RTX 3080
Dark Base Pro 900
Corsair RM1000i
It'd be better to use a splitter off of the motherboard cpu_fan header for pwm.
If you list your specs and budget, it would be easier to provide a recommendation.
Gigabyte z77x d3h
Intel core i5 3570k oc
Noctua NH-D15
Sapphire r9 390 oc
Fractal design define s
He doesnt care about the budget as he just bought the case because i recently got it and he likes how it looks :D
The goal is to be as quiet as possible.
5900X
MSI MEG X570 Unify
RTX 3080
Dark Base Pro 900
Corsair RM1000i
5 minutes ago, Alesek said:
Gigabyte z77x d3h
Noctua NH-D15
Sapphire r9 390 oc
NF-A15's or NF-S12A's would be optimal.
be quiet fans
Longboarders/ skaters message me!
how many would you recommend?
5900X
MSI MEG X570 Unify
RTX 3080
Dark Base Pro 900
Corsair RM1000i
If budget isn't an issue, I would fit as many of either as you can. NF-A15's would perform better and NF-S12A's would be quieter.
5900X
MSI MEG X570 Unify
RTX 3080
Dark Base Pro 900
Corsair RM1000i
