Air cooler that would fit in a aercool x1 with side.
igetaroundd
I'm looking for a decent small air cooler for my i5 2500k, for about £20-£40. I recently bought a hyper 212 but that wouldnt fit with a side fan installed.i'm planning to use the side panel fans as intake so a low profile cooler wouldnt work.
CPU - i7-10700K, MB -MSI Z490 Gaming PlusRAM-Corsair Vengeance Pro 3200MHz, GPU - MSI GeForce RTX 3070 GAMING X TRIO, PSU - EVGA 650w Supernova G2 80+ GoldStorage - Samsung 970 EVO 500 GB ,WD 3x Samsung 860 EVO 500GB, Cooler- Noctua NH-D15S, CASE Fractal Meshify 2 Compact
Aerocool X1 cpu cooler height limit is 158mm, with side fan you limit yourself to 133mm cpu cooler, there's not much choice if there's any for a tower I think.
Why not a low profile cooler? A Shadow rock LP would be ideal for that situation.
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
I was planning to use the side panel fans as intake, wouldn't that mess up the airflow?
There's a mixed result on whether blowing air towards the heatsink or away from the heatsink gives better cooling.
If you can find positive results on a cooler with fan blowing towards the heatsink itself on a low profile cooler then you can give that a shot I guess.
I'm gonna give the shadow rock lp a try
Just remove the side fan.
