120 mm fan for mineral oil submersion
Solved by Stefan1024,
1 hour ago, ThomasD said:You don't want a case fan, none of which are intended to perform against that much resistance. You want some sort of impeller - maybe a small submersible aquarium pump..
If I need serious oil flow, an impeller is the best solution. I was looking at some motors and impellers used for RC boats. But they are expensive and I don't need "that" much airflow.
I just bougth a Corsair SP120, it should be enougth oil flow. If I really need more for the OCed Titan X, I will have a look again.
