GPU AND CPU thermal throttling need help with air flow
ar300500
Go to solution Solved by DarkBlade2117,
24 minutes ago, ar300500 said:
I have reseated the heatsink on my cpu and used as5 instead of the stock cooler master stuff, I have checked all the fans. I might as well get noctua fan as before I found they were out of my budget so I went with the corsair ones thanks for the help.
Don't just jump on the Noctua bandwagon. You can easily get bequiet! or BitFenix fans which are both great companies and offer good products. Plus they don't use that horrid color scheme Noctua has.
Also, use the quote option :)
my current setup
GPU is a msi r9 390x gaming 8g (no overlocks)
CPU i7 4790k (no overclocks)
the two front fans are corsair sp120s
the rear is a 140 sp phantek fan
the top is a corsair af120
and I put a af120 infront of the gpu facing the side panel
the cpu cooler is a hyper 212
Why is the rear fan intake? It should be exhaust. Pull cool air from the front and exhaust it up and out the back/top. Heat rises.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
what cooler have you for the devils canyon?
so what are your temps?
ambient temps are important too ( living in the sahara or on the north pole makes a difference)
i'd suggest turning the rear fan to exhaust
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
Shit sorry it is an exhaust messed up the picture
Anything else
Anything else
What type of cooler is on your CPU?
Also, what are your temps?
The cpu cooler is a hyper 212 eve wit the stock fan
rear fan needs to be exhuast
4 minutes ago, Bl00dgod said:
what cooler are you running for the devils canyon?
I have a Corsair H110. I idle around 40°c. I replaced the fans on it with Noctuas though.
When playing overwatch my cpu went up to 85 max but stayed between 78-83 c
GPU went up to 94c max on high settings and stayed between 75-89c
The core clock of the gpu also decreased from 1100 mhz to 1030mhz
Oh ok you're fine with your cooler, whats wrong with the temps? Id be surprised with that setup and cooler that you're having temp issues
Yeah you're running too hot. What is your ambient temp?
the question about the cooler and temps was for ar300500 ;)
my devils canyon runs with a h100i gtx with noctua nf f12pwm and idles at ~40 °C too
my ambient temperature is around 25-30 c
Derp, mistook you for the OP. :D
ambient temp seem fine
did you try taking the air cooler off   !! WHILE SYSTEM IS OFF !!! remember to ground yourself ;)
and reseating it with fresh thermal compound?
oh myy, have you checked that the fan is moving and that the cooler is firmly secure?
Your airflow ect is fine.
Honestly, the best I could say is get better fans and a better cooler if you want cooler temperatures.
The fans are mediocre but get the job done just fine but if you want better fans beQuiet! or BitFenix have some good fans.
If you want a cooler CPU temperature, either go for like a BeQuiet! Dark Rock Pro 3 ( or similar Dark Rock products ) or go for an AIO.
From my experience, not much else you can do.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
on idle both cpu and gpu are 40-44c
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
Also could my psu affect the core clock as I have a 650w psu
the psu is fine for your system even if you OC the CPU and GPU
the core clock on your GPU depends on the heat, if there is too much then it clocks down               if thats the question
 if you sprint on a marathon and dont get enough "refreshing" then you continue walking
you should also keep an eye on a stronger CPU cooler as @DarkBlade2117  mentioned
