Would a fan on top of a PSU Work?
reapersivan
1 minute ago, brcdncn said:
I know it's ghetto, it's just that the cable management wont let me fit a fan, maybe that one, but it will be a tight fit
Dont see how it would help but if the pegs dont melt your good
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
The psu would long shut down before the rubber mounts melted.
I don't think that helps that much. Moving those cables aways and placing fan to intake from bottom will help.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Just.. Don't.. What are your GPU temps?
I need S340. But more Define S'ish
