SpeedFan 4.51 100% fan speed over 50c
Solved by hsjj3,
Speedfan's default controls set the fans to 100% whenever the related sensor hits 50C.
Since you are using the GPU as the sensor for PWM3, go to the "TEMPERATURES" tab in Image 2. Click on GPU. At the bottom, increase the warning temperature from 50C.
Featured Topics
jeanssullivan ·
Posted in General Discussion0 -
Krzysztoff ·
Posted in Laptops and Pre-Built Systems0 -
12
12
3
Fauzi ·
Posted in Troubleshooting3 -
SuperFlower ·
Posted in Power Supplies1 -
13
2
5
