Does length affect HDMI picture quality?
For practical purposes, there is only one type of HDMI cable, called a "High-Speed HDMI Cable", or a Category 2 cable. There are no other types of HDMI cables in the real world. The only people who say there are multiple types are just people reading wikipedia descriptions of the standard. The HDMI standard does define a specification for a "category 1" cable which is only rated for 720p/1080i 60 Hz or 1080p 30 Hz, but no one actually produces category 1 cables, they don't exist in the real world.
Even if they did, it would have no effect on image quality. Cables in modern digital standards have zero effect on image quality. The only thing they determine is the maximum data rate, which dictates the maximum resolution and frequency, though even that is rarely limited by the cable itself. Signals do degrade the longer the wire is, but this won't reduce image quality. If the signal degrades below the point where the monitor can interpret it, the image will drop out. You either get everything, or you get nothing. There is no in-between image quality. HDMI doesn't have a defined maximum length but it's usually considered good out to about 15 meters before you need amplifiers.
As for latency, we are talking about electrical signals here, not water flowing through a pipe. If you hook a light bulb to a battery, you aren't going to have a delay before it turns on just by using a longer wire, not on a practical scale anyway. Cables have no effect on latency no matter what standard you are using. All latency is introduced by the signal processors behind each port which encode and decode the signals, and by the display controller if it does additional image processing before rendering the image to the screen.
