6 minutes ago, gabeart10 said:
Is this real? It doesn't seem like it's real
otherwise X99, includes a 1440p 144hz IPS display, why 32GBs of RAM?
PCPartPicker part list: http://pcpartpicker.com/p/7smd8d
Price breakdown by merchant: http://pcpartpicker.com/p/7smd8d/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.49 @ Amazon)
Motherboard: ASRock X99 Extreme4/3.1 ATX LGA2011-3 Motherboard  ($219.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  ($53.99 @ Newegg)
Storage: Mushkin ECO3 240GB 2.5" Solid State Drive  ($64.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($303.98 @ Newegg)
Case: Fractal Design Define S ATX Mid Tower Case  ($69.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($84.99 @ Amazon)
Monitor: Acer XF270HU 144Hz 27.0" Monitor  ($549.99 @ Amazon)
Total: $1794.89
Generated by PCPartPicker 2016-05-22 11:08 EDT-0400
Just now, Streetguru said:
gpu wont be able to drive that display
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
Total: $1794.89
Could cut the PSU down to 600W and leave the GPU out until the 1080 comes around.
USEFUL LINKS:
PSU Tier List F@H stats
Games would need to be ran at 720p to hit 144hz fps, although the 390 is no slouch at 1440p either. Would need to wait for Vega potentially. Or polaris 10 should be pretty decent as well
my 290 is not maxing out 2560*1080 :D
no point getting 144hz. just go for freesync.
http://pcpartpicker.com/p/vbC2Q7
PCPartPicker part list: http://pcpartpicker.com/p/vbC2Q7
Price breakdown by merchant: http://pcpartpicker.com/p/vbC2Q7/by_merchant/
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($339.99 @ B&H)
Motherboard: Gigabyte GA-Z170X-SOC FORCE EATX LGA1151 Motherboard  ($379.99 @ Amazon)
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory  ($84.99 @ Newegg)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  ($317.00 @ Amazon)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($316.99 @ Newegg)
Video Card: EVGA GeForce GTX 980 Ti 6GB K|NGP|N ACX 2.0+ Video Card  ($825.99 @ B&H)
Case: Phanteks Enthoo Evolv ATX ATX Mid Tower Case  ($179.99 @ Amazon)
Power Supply: EVGA SuperNOVA P2 750W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($109.99 @ Amazon)
Case Fan: Noctua NF-A14 PWM 82.5 CFM 140mm  Fan  ($21.99 @ Newegg)
Case Fan: EK Vardar F4-120ER 77.0 CFM 120mm  Fan  ($22.95 @ Amazon)
Other: EK predator 360 ($250.00)
Total: $2939.75
Generated by PCPartPicker 2016-05-22 11:19 EDT-0400
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
10 minutes ago, gabeart10 said:
This is my first build ever and I am just making sure that it is fine.
http://pcpartpicker.com/p/zrXKJx
Yes, ik that 32 is a bit much, but I just had the money.
some curved freesync goodness incoming:
PCPartPicker part list: http://pcpartpicker.com/p/gQfsHx
Price breakdown by merchant: http://pcpartpicker.com/p/gQfsHx/by_merchant/
CPU Cooler: be quiet! Shadow Rock 2 51.4 CFM Rifle Bearing CPU Cooler  ($49.90 @ NCIX US)
Motherboard: ASRock X99 Extreme3 ATX LGA2011-3 Motherboard  ($168.99 @ SuperBiiz)
Memory: G.Skill NT Series 16GB (2 x 8GB) DDR4-2400 Memory  ($53.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($57.10 @ NCIX US)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($62.09 @ Amazon)
Video Card: XFX Radeon R9 Fury X 4GB Video Card  ($629.99 @ Amazon)
Case: Fractal Design Core 2500 ATX Mid Tower Case  ($55.99 @ Directron)
Power Supply: XFX XTR 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($93.99 @ SuperBiiz)
Monitor: BenQ GL2760H 60Hz 27.0" Monitor  ($169.00 @ B&H)
Monitor: BenQ GW2765HT 60Hz 27.0" Monitor  ($349.00 @ Amazon)
Monitor: Acer Predator XR341CK 75Hz 34.0" Monitor  ($917.99 @ NCIX US)
Other: intel 6800k ($380.00)
Total: $2988.03
Why that 2TB SSD though? Just get a 250GB one and a regular HDD.
32GB of RAM is an overkill for a consumer grade set up, you won't be using half if you are just gaming etc.
I'd probably wait for the new GPUs to arrive before buying a system if I were you.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
I'd imagine it still runs most games at medium-high easily though
12 minutes ago, DeezNoNos said:
If one's budget is well over 1k is probably going to be a guarantee to go for X99
Well the other parts are better
Build
ya...but it's probably unnecessary/overkill, and it's missing a monitor
yeah i forgot that......
Build
