Pole Time: Operating CPU temps
15 members have voted
  1. 1. What do you think is the max temperature before the CPUs regress?
    • 100° C (212° F) - 150° C (302° F)
    • 151° C (303.8° F) - 200° (392° F)
    • 201° C (393.8° F) or higher
  2. 2. What do you think is the max temperature before CPUs destruction?
    • 100° C (212° F) - 150° C (312° F)
Hey, guys. Just curious. I want to know the maximum temperature for the CPU to stop operating, and the maximum temperature for the CPU to shrivel up. Any responses would be helpful.
RIP Arctica 2.0 (December 2015 - September 2016) You were the best freezing cold gaming/video editing/CAD PC I've ever built.
"Look deep into nature, and then you would understand everything better" - Albert Einstein
"Discontent is the first necessity of progress." - Thomas Edison
"No." - Linus Sebastian
Arctic Raider (Main Rig) - CPU: i5-6600K @ 4.4 GHz | CPU Cooler: Cryorig H7 | Mobo: Asus Z170-A | Memory: 16GB Corsair Vengeance LPX DDR4-3000 | Video Card: Asus GTX 1070 Dual Series | HDD: 2TB Hitachi Deskstar 7K3000 | SSD: 512GB Sandisk X400 M.2-2280 | Case: Corsair Carbide 400C (White) | PSU: 750W EVGA SuperNOVA P2 | OS: Windows 10 Pro | Keyboard: Cooler Master Octane | Mouse: pre-installed with keyboard | Headphones: Corsair Void 7.1 Channel | Monitor: 23.8" Dell S2417DG 1440p | Fans: 2x 140mm Corsair AF140 Quiet Edition; 1x 120mm Corsair AF120 Quiet Edition | Modding/Extras: BitFenix Alchemy 2.0 Black/White Sleeved Cables; Tingkam RGB LEDs (2 x30cm); Solid Base Elite Headphone Stand; Reflex Lab White-Stitched Mousepad
https://linustechtips.com/topic/599300-cpu-temperature-max/
Depends on the CPU, but usually at 100 C they just turn off (earlier depending on the CPU.
You should probably not let your CPU run hotter than 85 C though. (again, depending on the CPU)
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779349
100*C is when the solder falls apart.
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779355
Would actually be interesting to see which temp it takes to fry a CPU cause I have no real clue to be honest. Nowadays the only thing they tell you is the TCase which tells you absolutely nothing except for that I guess it'll shut off when it gets to that temp!?
CPU AMD Ryzen 5 5700X3D | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G
Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GBPrograms: Samsung 990 PRO 4 TBData: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W
Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming
Sound Card: Creative Sound BlasterX AE-5 Plus, System: Edifier R1280DB | Magni/Modi Schiit Stack  | OS Windows 10, 64 Bit
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779357
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779371
solder melts at 188C
an intel CPU's TJ max is 105C where it shuts itself off
anything over 95C is unsafe
for AMD CPUs anything over 65-70C is unsafe
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779372
I guess I should rephrase - continuous work at 100*C WILL degrade the solder
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779378
not necessarily :)
with RC you can get components that go over 150C and the solder holds up just fine
over 100C severely degrades the silicon and transistors inside the CPU, and all those tiny traces and stuff
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779382
2 minutes ago, josephaltareb said:
i never knew that.
Depends on which CPU though. Mobile AMD chips don't have such low thermal limits and can go up to 90*C without shutting off (as shown by the 8800P).
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779384
i just thought that amd's cpu has a higher tdp than other intel cpus, therfore the temp before it shuts down is higher.
apparently im not.
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779393
apparently im not.
Nope - hence why the stock cooler on AMD (Wraith Cooler) is several times better than the stock cooler on Intel (which sucks balls for anything above a locked i5)
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7779396
Ive never really agreed with the stigma on the intel cooler, as long as the mounts are correctly seated i could do 4.4 at 1.25 easy with the stock cooler at only like 80c
Intel i5-3570K/ Gigabyte GTX 1080/ Asus PA248Q/ Sony MDR-7506/MSI Z77A-G45/ NHD-14/Samsung 840 EVO 256GB+ Seagate Barracuda 3TB/ 16GB HyperX Blue 1600MHZ/  750w PSU/ Corsiar Carbide 500R
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7780875
At around 160C, according to Wikipedia, semiconductors start decreasing in electrical resistance. Meaning it starts pulling more current. More current means more heat, which means even less resistance.
Basically that's the "maximum" point you can operate a semiconductor because it'll start quickly destroying itself.
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7780897
My 4590 on the properly mounted and pasted cooler got quite hot so I am confident it's crappy.
https://linustechtips.com/topic/599300-cpu-temperature-max/#findComment-7781800
