Hi, I have a intel core i7-6700K and has 91 watts of heat. I chose NZXT Kraken X31 69.5 CFM Liquid CPU Cooler but I'm not so sure. Since I'm new to custom pcs, I am planning a full water cooled. Pump, reservoir, tube, cooling surface, whatever. Everything needed for water cooling included. Help me what should I get and budget is 100~200$.
https://linustechtips.com/topic/594807-what-water-cooler/
$200 isnt enough for a custom loop
you should save up $400-600 before considering doing one
for $200 you cna get a good aio like a H110iGTX or kraken X61
https://linustechtips.com/topic/594807-what-water-cooler/#findComment-7732395
