Anybody know of a fan larger than 200mm?
RGProductions
So I am designing a custom PC case and the way I want it it would be beneficial to have larger than 200mm fans, anyway, just wondering if anybody knows of any?
M1 MacBook Air 256/8 | iPhone 13 pro
Nope. Fans bigger than 140mm are generally not the highest quality either.
Anything larger than 140mm suck imo
CPU: i7 5820k @4.4GHz | MoboMSI MPower X99A | RAM: 16GB DDR4 Quad Channel Corsair LP | GPU: EVGA 1080 FTW Case: Define R5 Black Window | OS: Win 10 Pro
Storage: SanDisk Ultra II 960GB 2x WD Red 4TB | PSU: EVGA 750W G2 | Display:Acer XF270HU + Dell U2515H | Cooling: Phanteks PH-TC14PE
Keyboard: Ducky One  TKL Browns | Mouse: Steel Series Rival 300 | Sound: DT990s
yes, I know usually they suck but I have kind of a unique idea that will be a bit of a tight squeeze with a 200mm fan, but it will work.
22 minutes ago, ColoradoJones12 said:
BitFenix sells quite a few 230mm fans
yeah, but the fan blades I believe are the same as 200mm fans
Avoid Cooler master 200mm, I'm using one, it sucks
just use the 180 air penetrator from silverstone, best large fan
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
Like said, few 140mm fans is better in performance than 200mm+ fans. As user of 200mm fan, I can say its ok if you need to cool multiple not-so-hot parts, like HDDS. But for more targeted flow, go for 140mm's.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
bitfenix does 230s. idk about the performance but they look reasonably well build.
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
