Starter Components for hobby electronics
Diodes:
1N4148 small signal diode - general purpose.
1N4007 diode - rectifier.
Transistor:
BC547/BC557 - small signal, basic switching.
BC337/B327 - Can handle up to 800mA, i like these for driving the common on 7 segment displays.
Regulators:
78XX - Where XX is the voltage, for example 7805 is a 5V regulator, i stock some common voltages such as 5 and 12V.
LM317 - Adjustable voltage regulator.
Resistors:
A bit of everything in the E12 series goes a long way.
Capacitors:
Most common used:
0.1µF (100nF) - Basic filtering, power supply decoupling.
1000µF - Buffering after rectification.
If you're going to play with timers like the 555 other capacitor values might be handy but you can always play with the R (resistor value) in the RC to adjust time values. If you want to play around with filters then other capacitor values will quickly become a must.
Leds:
LEDS! and some 7 segment displays perhaps ?
Pushbuttons and switches:
Because you need input at some point.
That's all i can think of atm ![]()
