Best quiet 140mm case fan x4
trzasku
I am building a near silent PC running an Dark Rock Pro 3 cooler. I want to fill the 3 front and the rear slot of my Define S case with some good quiet fans to achieve some strong positive pressure to avoid dust. I want to run all those fans at about 30% to keep the PC as silent as possible. I am not looking for the most quiet fans out there (it is easy to have a silent fan that does not move air), but for those which noise/performance ratio is the best.
At the moment I have the two GP-14 fans that came with the case, they are pretty quiet at 33%. My question is:
• Will there be a audible difference if I change this two GP-14 for something high-end or should I just buy 2 more of them to fit the design (I do not like to have different fans on the front) ?
I think the best noise/performance 140mm fans are (price in my country):
  • Be Quiet! Pure Wings 2 $11
  • Fractal Design Dynamic GP-14 $16
  • Be Quiet! Silent Wings 2 $23
  • Noctua NF-A14 $24
But I am not sure which of them should I choose. I do not want to overpay for something that is only a slightly better than my GP-14 case fans. What would you buy in my situation?
I was looking for some up to date fan comparison but almost every chart is different. Can you recommend me a good chart with the most popular quiet fans?
Noctua is the best of all of those, as for a chart, I'm not sure. You may be able to find a biased one on the company web page for one of those.
ASU
You don't have the Fractal-Design Venturi HP-14 in your country?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
I agree with the noctua suggestion, very very good fans, shift a lot of air and are so quiet :)
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
And what whould you choose on second and third place? (I also care about looks and good case fit).
22 minutes ago, Aytex said:
None of thoes
Phanteks PH-F140XP_BK 140mm
Phanteks PH-F140HP is better that the XP by a lot (although it is more suited to heatsinks than case fans with it's odd shape)
But uhh
Noise (at top speed)
Silent Wings 2>GP-14>Pure Wings 2> Noctua NF-A14 (yes you heard that right at top speed the Noctua is the loudest on this chart).
Performance (at top speed)
Noctua NF-A14>GP-14>Silent Wings 2>Pure Wings 2
Performance (at similar noise levels)
NF-A14=GP-14>Silent Wings 2>Pure Wings 2
For the price the GP-14 fans are fantastic (although they are lower consistency and quality than the noctua's).
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
Oh and the GP-14's are available in black...
But uhh
still cheaper than noctua :^)
@Curufinwe_wins do you have some charts, how do you know all of this? If the GP-14 fans are really that great that is fantastic because I only have to buy 2 more instead of 4 other fans (I want all the same fans).
Yerp.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709043
Although the first gen ones sell for like 60 bucks on newegg.
http://www.newegg.com/Product/Product.aspx?Item=9SIA0AJ2KE7057
1. Old review on scpr: covers some of the fans you listed (note never at near top volume) http://www.silentpcreview.com/article1345-page7.html
2. Top end noise is easily located and decently accurate (GP-14 is ~18 dbA, SW-2 ~16 dbA, PW-2 ~19 dbA, A14 ~24.6 dbA.)
3. Pure Wings are just always inferior to Silent Wings (lower end fans)
4. Experience around the forum (and personally with most of these fans) helped place the GP-14 in the stack (there is a group of very die hard lovers of it out here.)
We are talking about the GP-14 from Fractal Design right?
Yep
If you can afford it, go with SW2's. It doesn't really get better for 140mm case fans.
