Hi guys,
Been a while since I've been active on the forums :)
I've been super busy with a new job, move to a different city and pretty much a whole new life!
Glad to say that I'm back and with a very exciting project!
As the banner suggests it will be based on the Dead Space games and it's my entry for this year's Cooler Master Case Mod World Series as well as the ANZ Edition of the "World Series".
I am going all out with for this project and trying some modding techniques I haven't done before so stay tuned and enjoy the build log! I'm gonna give a little hint and say that this will NOT be a clean build :)
I would like to say a huge thanks to Cooler Master Australia for giving me this opportunity as well as ASUS Australia, Kingston HyperX, Avexir, Bitspower, Primochill, CableModPLE Computers and a new addition from a friend of mine, Kristian from MercoMods!
SPECS
Case - Cooler Master MasterCase 5 Maker
Motherboard - ASUS Maximus VIII Extreme Assembly
CPU - Intel i7 6700K
Memory - 4 x 4GB Avexir ROG Certified Red Tesla 2400Mhz DDR4
GPU - 2 x ASUS STRIX GTX 980
SSD - 2 x Kingston HyperX Fury 240GB SSDs
PSU - Cooler Master V1000
Cables - CableMod Fully Custom Individually Sleeved Cables + MercoMods Custom Braided Extensions
LEDs - CableMod Magnetic RGB LED Strip
Radiators - Bitspower Leviathan Slim 240 Radiator, Bitspower Leviathan Xtreme 360 Radiator
Fans - CoolerMaster JetFlo 120mm Red and White LED fans
Pump - Laing D5 with Black Bitspower MOD Package - Pump Top + Casing
Reservoir - Bitspower D5 Top Upgrade Kit 150 with Cascade Tube Effect
Fittings - PrimoChill Revolver SX Matte Black + Various Bitspower Carbon Black angle fittings and extensions
Tubing - PrimoChill Copper Tubing
CPU Block - Bitspower Summit EF
GPU Block - 2 x Bitspower VG-NGTX980ADIIS
For now I'll start with the packages received from Cooler Master :D
A mysterious box (though the thread title might hint at what's inside)
JetFlo fans and a V1000 power supply
Stay tuned for more guys!
Cheers,
Alex
SIMPLE MODZ
VAULT BOY - A Fallout inspired build  (Featured Build - December 2014) - GREEN MOLECULE - TOXIC CHROME - PARVUM FORMULA
Following because it looks awesome, but 12 fans? Does the case even take 12 fans? Wouldn't you need a push/pull rad on every fan spot or something?
Edit: now I see
Tip to those that are new on LTT forum- quote a post so that the person you are quoting gets a notification, otherwise they'll have no idea that you did. You can also use a tag such as @Ryoutarou97 (replace my username with anyone's. You should get a dropdown after you type the "@")to send a notification, but quoting is preferable.
Feel free to PM me about absolutely anything be it tech, math, literature, etc. I'll try my best to help. I'm currently looking for a cheap used build for around $25 to set up as a home server if anyone is selling.
If you are a native speaker please use proper English if you can. Punctuation, capitalization, and spelling are as important to making your message readable as proper night theme formatting is.
My build is fully operational, but won't be posted until after I get a GPU in it and the case arted up.
awesome :D looking forward to this a lot!
Builds:
19 hours ago, ImmyCakes said:
Looking Forward to seeing the completed video xD
Hehe cheers - there might be a video or perhaps more :P
Edit: now I see
Thanks mate! And the reason for 12 fans was that I wasn't sure at the time when I requested these what colours and whether I am doing push/pull or just one set of fans. So there are a red and white LED ones in there with most likely the red ones being used with white lighting coming from an RGB strip but I haven't fully decided on the whole lighting set up yet :)
Thanks a lot :D
SIMPLE MODZ
Hi guys,
Here's a look at the glorious CoolerMaster Master Case 5 Maker! A good improvement from the 5 Pro :)
New integrated fan controller and LED controller with one red LED bar included.
The front section is easily removable with clips at the bottom and magnets at the top, revealing the front intake mesh and 5.25" bays. The front panel is also padded with sound dampening material.
Sound dampening cover for the top as well with air still being able to be exhausted through the back or front sections of the top panel.
The top sound dampening cover can be removed, with clips towards the front and magnets in the back.
The top slide on cover now has integrated magnets as well, towards the front for a better grip.
The included magnet LED bar. This one is red and not sure if case will come included with different colours.
Thanks for checking it out and stay tuned for more guys!
Cheers,
Alex
SIMPLE MODZ
Epic, Dead space build? Sign me up.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
5 hours ago, nmil said:
Subbed once again. What city did you move to?
Sydney :) Need to update on the forum :P
Cheers man :D
3 hours ago, Murdy007 said:
Did you buy all that stuff or did cooler master end it to you? If so, how?
Check out my other builds if you haven't seen and you'll understand how. This is my 12th mod according to my list of projects :D:P
SIMPLE MODZ
Hi guys,
I'm prepping the case for painting but doing some mods first :)
Ignore the smaller scratches, I was just trying something. The paint will cover all that and might even stick better now :P
The large scratch looking cuts were done with the dremel! The melted plastic is exactly the effect I wanted. Once it's all painted you will see :D
Let me know what you guys think so far and stay tuned for more!
Cheers,
Alex
SIMPLE MODZ
Argh. This makes me want to replace my Mastercase Pro with the Maker.. :/
It looks so good.
It looks so good.
I'm pretty sure you can buy the extra parts in the CM store soon -> I will be doing the same ;)
I so want that tempered glass panel they showed off a couple weeks ago...
That would be really helpful.
I love the front panel the most.
Since you can buy all the parts to upgrade the standard Mastercase 5 to the Pro version, I dont think it will take long :)
this going to be fun... I rather enjoy you messing up your hardware in order to make it look cool in the end :) So opposite anything I would ever do.
On 02/05/2016 at 7:20 AM, rowanhazard said:
Looks epic
Thanks a lot :D
It looks so good.
It's awesome :D
Yup should be able to buy parts and mix and match from Pro to Maker. Internals are identical :)
Haha cheers :D All my builds so far have been clean looking, this is the first time I'm attempting something like this :P
SIMPLE MODZ
Hi guys,
I have another update for you!
This time showcasing the Cooler Master V1000 power supply as well as the JetFlo fans!
The fans are red and white LED, I got more than I needed as I'm not sure how I'm gonna combine the colours in the build.
Also, the banner has been update with PLE Computers joining as a sponsor! PLE Computers is one of the best online computer store in Australia with lots of variety for water cooling on top of all the normal components. They even stock Linus' special edition Noctua fans as well as the LTT hoodies. If you're an aussie, check them out if you haven't already :Dhttps://www.ple.com.au/
Some pretty powerful fans but they also come with voltage reducers for lower RPM and noise :D
As we as proprietary screws for the anti-vibration soft corners on the fans which are removable.
With these fans the LEDs are in the middle with the light shining towards the edges creating a nice effect.
All black and sleeved cable
Thanks for checking it out guys and stay tuned for more!
Cheers,
Alex
SIMPLE MODZ
Hi guys,
I've got an exciting update for you today :D
Since this is a Dead Space theme I'm looking at a different painting technique for the entire case!
So I'm testing out this rust paint to see if it's the effect I'd like to go for in this build as well as learning how to apply it. Luckily I have quite a few spare case panels laying around.
The idea with this is that it can be applied to anything, even plastic and rust that too. It's a metal based paint which you apply with a brush and leave it to dry for about 1 hour. Once dry you apply the oxidising patina which is a form of activator that speeds up the rusting process. Leave it for a few good hours and you should have a nice, real rust effect.
So tonight I've applied it to a spare case panel. I did a few different areas where I applied it on straight as well as in a random pattern to see if it gives a different effect or if it even matters how you apply it. I've then applied the activator and leaving it overnight. I've also applied the activator to a part of the panel with no metal base paint as technically this should rust metal by itself too, however it might not go through the powder coating on the panel.
This is the stuff and how it looks after about 30 min since the activator was applied. I'll show you guys the effect tomorrow once it fully dries.
This is the rust base applied.
This is once dried.
And this is the Oxidising Patina applied.
Applied some more as the more you have on and the longer it stays wet for, the more intense the effect will be.
You can already see it starting to rust here.
This is after about 30 mins with the activator applied.
We'll see the full effect tomorrow once it dries.
Hope you guys have enjoyed this update! I'm definitely really excited for this entire project!
Thanks for checking it out.
Cheers,
Alex
SIMPLE MODZ
11 hours ago, Anthony_95 said:
@Slick will be very useful in this project ! xDxD
lol why's that? :P
SIMPLE MODZ
Hi guys,
So here is the effect after about 24 hours once fully dried!
I gotta say I wasn't expecting this but it's the perfect effect I wanted for this build :D
It seems like applying in a straight even motion looks a bit better than the random pattern I did in the corner of the panel. Also the oxidising patina by itself didn't do much to the poweder-coating. I wonder how it would affect bare metal :)
Anyways, here are the result. Next up will be applying it to the case!
Thanks for checking it out!
Cheers,
Alex
SIMPLE MODZ
On 09/05/2016 at 5:23 PM, ciobanulx said:
lol why's that? :P
Luke did a Mad Max themed build for Scrapyard wars, and they tried to give everything a rusted look.
Check out my YouTube channel here and don't forget to subscribe :D
Current build: Project Athena
On 9/5/2016 at 9:23 AM, ciobanulx said:
lol why's that? :P
yes ! Also because of this:
 11:08 is top :D:D
 11:08 is top :D:D
Hahaha yes I've seen it all :P
SIMPLE MODZ
