So I've had my 970 for a while now, since the release date last year and I've not really been paying attention to the thermals and overall performance etc.. as it's been performing fine
But I just went to check out of curiosity and it seems to get pretty hot (hitting 91c after only playing Rise of the Tomb Raider for 10mins)
The cooler on my 970 isn't the best as it's only a blower-style cooler (Like a reference card) the brand is Palit.
Here's a screenshot, what do you think?
Thanks for any help in advance :)
CPU: Intel Core i7-4790K | GPU: GTX 1080Ti | Case: Corsair 750D Airflow | Motherboard: ASUS Maximus Formula VI | RAM: 16GB Vengeance Pro | PSU: Corsair AX860
SSD/HDD(s): SAMSUNG 850 EVO 120GB, SAMSUNG PM830 256GB, SEAGATE 6TB | Optical Drive: Sony Optiarc AD-5280S CB-PLUS
https://linustechtips.com/topic/587149-gtx-970-overheating/
Max for maxwell is 85*C so that's dangerous right there
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648921
I would replace the thermal paste and dust out the cooler.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648923
I could check if it's still in warranty first and if not then I could do that as a plan B
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648939
That is really fucking high. Can you post screenshots of your fan configuration in your case?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648956
1 minute ago, Moonzy said:
how is the case air flow configured? `-`
it could be that too
1x Front intake
2x Front intake with aio in the middle of the 2 fans
1x Back exhaust
1x Top exhaust
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648962
1 minute ago, kyle_987 said:
1x Front intake
1x Back exhaust
1x Top exhaust
negative pressure isnt that great for blower cards
try swapping the radiator to top or rear as exhaust
edit: also, try channeling the air to the card directly, preferably not from the AIO as that air is slightly warmer
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648969
3 minutes ago, kyle_987 said:
1x Front intake
1x Back exhaust
1x Top exhaust
There doesnt seem to be anything bad here, so you might need to repaste the GPU, or RMA if you're not comfortable with that.
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648980
It's an easy simple thing to do, and usually doesn't void the warranty. (Unless there's one of those stickers on the screws.
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648984
I could definitely do that right now but if it doesn't fix the problem I don't currently have the money to get another card right away and I do play a lot of games lol
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648985
Yeah there's a sticker on it lol
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7648987
I understand what you mean but I don't think that the 1x extra fan could be doing that much harm could it? I'd bet it would hardly make a difference tbh
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649002
I hate it when manufacturers do that. XFX is nice and are fine with that unless there's pcb damage.
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649005
I know, I feel like such a noob for not just waiting until the store re-stocked with different brand cards, When i bought it this was the only brand left in stock as all of the other ones had sold out due to me buying it on the release date
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649010
hard to say, blower cards prefer positive air pressure
negative pressure would be restricting it from cooling itself properly
if you're lazy to configure your fans, try opening your side panel and run it, see if that helps
if it does then its probably the fan placement, and possibly thermal compound too
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649021
Alright I'll give that a test and post results, give me 5 minutes
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649031
13 minutes ago, kyle_987 said:
1x Front intake
1x Back exhaust
1x Top exhaust
Looks like you're feeding hot air into your case.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649038
First try getting as much dust out of there as possible and reposition the AIO to an exhaust spot. Also make sure you have positive air pressure inside the case.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649077
There was a 9c difference, Isn't 82 still kinda hot though or is that normal?
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649105
given its a stock cooler, its about normal, maybe a bit higher
but atleast within the 85c safe zone
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649118
I could possibly get a hg10 n970, Do you think it will fit my card? as I think I may have a H80i somewhere that I could use from another PC to dedicate to my card.
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649127
I could possibly get a hg10 n970, Do you think it will fit my card? as I think I may have a H80i somewhere that I could use from another PC do dedicate to my card.
i wouldnt bother tbh
i would just switch to positive air pressure and observe the temps, as long as its below 80c then it should be fine
positive air pressure should aid it slightly too, opening the side panel is just neutral pressure lol
https://linustechtips.com/topic/587149-gtx-970-overheating/#findComment-7649134
