3 pin fan control with speed fan?
GeorgeKellow
if your motherboard supports it yeah
but speedfan doesnt always work properly on all motherboards
I've got an MSI Gaming 5 motherboard
apparently you can voltage control them
https://forum-en.msi.com/index.php?topic=255368.0
check if MSI has some software for this, or maybe its in the bios
Just now, GeorgeKellow said:
Its got command centre which I can control, but i can only go as low as 50%
well yeah
thats normal
if you go below ~40% on a 3 pin fan it will stop
1 hour ago, Enderman said:
well yeah
thats normal
Depends on the fan. Noctua's can go as low as 17%
SpeedFan should be able to go lower.
on a non-PWM fan??
i highly doubt that
on a non-PWM fan??
i highly doubt that
I agree. Some have start speed at 30-35% but not really lower than that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
3 minutes ago, Enderman said:
on a non-PWM fan??
i highly doubt that
Yes, non pwm. Pwm Noctua's can go down to 7%.
I didn't believe you, so I took my NF-P14 and plugged it into 4.5v and no, it does not turn. It needs about 5v to start, which is about the 40% duty that I claimed earlier.
What fan header are you running it from?
I used a 4.5v power supply, not a PC fan header, to make sure the fan could get all the current it needs for startup
I'm not sure if it makes a difference but NF-P14's have always started up for me past 17% when running off of a motherboard fan header. Try doing that with SpeedFan or through the motherboard settings.
You sure you're not using PWM?
Cause I have a P14 PWM and it certainly does work down to about 10 or 20% when on PWM mode (my motherboard can switch between DC and PWM too)
Yes, I'm sure. I've had several pwm and non pwm NF-P14's and was annoyed that I couldn't run all of my fans at 7% until I moved to all pwm Noctuas.
huh weird
idk then
