24 Volts Case fans
Antony Leung
So i only have a doubt about the 24v fans that  you can see here:  http://www.amazon.com/dp/B0187IB5YG this is 140 mm and the 120mm is https://www.amazon.com/dp/B0187IB8ZM
Is this will work with the build im planning. you can see the main post here:
PCPartPicker part list: http://pcpartpicker.com/p/2233zy
Is this safe voltage for the motherboard those 24V fans? The MOBO IS ASUS Z170-PREMIUM.  the CPU is I7-6700k.
Anyone had experience 24 volt fans?
this will work with this  Noctua NA-SYC1 Accessory 4-pin Y-Cables for PW. im mean about the voltage.
ANY FEEDBACK, COMMENT, IS WELLCOME and I’ll be thankful and pleased
Edited by Antony Leung
Update
1) a computer PSU does not provide 24v
2) those fans will run at 12v and half speed
3) those fans are loud
4) your PC is not an industrial server
do not waste money on fans that you cannot use properly
5) if you put 24V into a motherboard you will have a fire
you'll have to get some sort of voltage converter, because your psu only supply a maximum of 12V
just get normal fans like Enderman suggested
-sigh- feeling like I'm being too negative lately
First: Thanks guys for the feedback.
Ok, now Can you guys tell me another good option for case fans that is better than the stock fans of the h115i cpu liquid cooler and some good static pressure fans and airflow.
i only heard about noctua and corsair be good.
Maybe look for Redux Noctuas? They too are dark-ish.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
