Hey guys! I want to build a gaming PC. I want a i5 6600 (locked version). I will be using a MSI H97 GAMING 3. But now on PC parts picker, I put the motherboard in, and now when I try to search for my processor, it does not show the i5 6600 or the unlocked version. When I realised that I had the "Enable compatibility filter" checked..
Is it a bug or can the i5 6600 really not go with the MSI H97 GAMING 3?
https://linustechtips.com/topic/583155-i5-6600-not-compatible/
It doesn't and shouldn't, its a different socket.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609666
Pick a H170/B150 board for that.
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609668
As stated, the sockets are different. H97 uses LGA1150, while the Core i5 6600(Skylake) uses LGA1151. They are not compatible.
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609678
2 minutes ago, Telebubbies said:
The 6500 is also not compatible..
Do you already own the board?
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609684
ITS THE WRONG SOCKET PLEASE LISTEN MAN, ok sorry for that but relly, you need a something with a 1151 socket on it and the H97 chipset dosent have that socket, it has 1150. get a H105 board instead and is should be fine also get the 6500 instad because like stated its not worth the extra money to get a 6600 :)
Builds:
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609686
Just now, Telebubbies said:
Do you know any H170 boards that take DDR3 RAM and not DDR4? My CPU cannot take DDR4 and I really want a cheaper board.. I already spent $300 over my budget limit..
The DDR3 board aren't cheaper unfortunately, and the i5 6600 (though the i5 6500 is better in terms of value) does take ddr4 by the way.
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609689
your CPU can take DDR4 and DDR3L (low voltage DDR3)
there are B150 boards that take DDR3L, just filter them out on pcpartpicker
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609691
Tell us whats up ... What have you already bought what are you planning budget. Please don't puzzle us with a random fact here and there.
3.Use
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609693
Erm yes, the i5 6500 does use the same socket as the i5 6600.
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609695
I know.. I am asking what board I should get so I can get the i5 6600.. I know that it is the H170, but I want to know which brand would be the best..
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609699
they are all good
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609703
Officially, Intel does not recommend the use of normal DDR3 on a Skylake CPU due to voltage. Now people can say whatever they wish, but Intel does not recommend the use of normal DDR3, so if you do go with a Skylake DDR3 based board, use DDR3L.
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609704
go with MSI or gigabyte, you cant go wrong with them :) or ASRock, i trust them but some dont, they are more of a cheepo option
Builds:
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609705
No.
k in conclusion:
the i5 6600/6500 will only fit in B150, H110, H170 and Z170 motherboards thats LGA1151 socket
some motherboards allow DDR3L, not DDR3, they're different and using DDR3 will damage the skylake's imc in the long run
DDR4 is prefered for skylake
any board that fits your bill should do just fine
make sure its the right size and have the ports you need and you're golden
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609707
Alright. I am going to redo the RAM, motherboard and CPU. When I am done can I send the specs to you and can you tell me if everything is good? :)
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609714
You can certainly send the specs to me for verification.
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609719
Ignoring the fact you can easily hammer 1.8V Through DDR4 On skylake, same as DDR3.
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/583155-i5-6600-not-compatible/#findComment-7609764
