Choose either intel or AMD along with the max temp you reach.
18 members have voted
  1. 1. What temps and what make?
Choose either intel or AMD as your CPU manufacturer, if you are not at any of those numbers in the poll then round it to the nearest, if you need help with rounding numbers just ask here, i am sure many of us will help you.
It would be really nice if people could tell us what the actual CPU is, the cooling, ambient temps and any overclocking, so please do spare the time to make a detailed post :)
If it is below the minimum choosable option please do explain.
CONSOLE KILLER: Pentium III 700mhz . 512MB RAM . 3DFX VOODOO 3 SLi
https://linustechtips.com/topic/571782-what-is-your-max-load-temperature/
For my choice i run a dual core Phenom II x2 555 BE unlocked into quad at 4020mhz on 1.46volts under a Coolermaster Hyper TX3, it reaches 55c max all day long with an ambient of 26c.
for the CPU around 90*C on the hottest core under Intel Burn Test with 10GB of memory
I don't have precise measurements for the ambient but it is quite high, if I had to guess it'd be around 24~25*C
for both GPUs it's around 80*C under Furmark
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
4790k -5 GHz@1.365v delidded with a custom loop. will hit 77°c after an hour of small fft prime 95 with fans at max, 80c with fans at 1200rpm
 21°c ambient
gaming is in the 40-50's
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
 21°c ambient
Reasonable temps and intel run a higher temp as normal so really good temps.
IBT only hits 70°c on max settings w/ 16gb RAM
