How can I improve my internet speed?
Wasard
Switch to a better ISP or upgrade your bandwidth
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
Move the modem as close to the service entrance in your house that is about all you can do (not going to do much but if there is a problem with your wiring inside your house it might help) aside from finding another provider.
Note upgrading your bandwidth will probably not help at all.
How will changing my isp improve my speeds? I still go through the same exchange right?
Use cable it should be better if you have that as well maybe even a 4G service (it will have data caps).
If you use the same physical wire there is going to be no improvements.
Cable isn't available where I live, I live in a rural area.
Is there 4G service in your area?
I'm not sure, how do I check?
2 minutes ago, papapoi said:
how much bandwidth are you paying for?
I asked my parents that, the had no clue. Is there a way I can check that?
You get whatever you pay for, unless there is something wrong. Are you getting lower speeds than what your paying for? If so, we can troubleshoot that, if not, then your only option is to upgrade to a faster plan.
Gaming - Ryzen 5800X3D | 64GB 3200mhz  MSI 6900 XT Mini-ITX SFF Build
Home Server (Unraid OS) - Ryzen 2700x | 48GB 3200mhz |  EVGA 1060 6GB | 6TB SSD Cache [3x2TB] 66TB HDD [11x6TB]
https://vzwmap.verizonwireless.com/dotcom/coveragelocator/
Verizon Wireless Coverage Map
https://www.att.com/maps/wireless-coverage.html
Select data and look for the 4G colors.
http://www.t-mobile.com/coverage-map.html
https://coverage.sprint.com/IMPACT.jsp?
There are also things like,
http://www.sensorly.com/
Also note with 4G you may get better speed (possibly even much better speed) if you are within good signal areas but you will be limited by data caps restricting how much you can download/stream. You probably also would want a mast mounted antenna and booster as that can make your signal much much better.
At the speeds reported they can probably use the lowest speed plan they are down in the physical limitations of ADSL.
Bruh, those are the speeds I have to live with xD
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[i7-7700k@5Ghz | MSI Z270 M7 | 16GB 3000 GEIL EVOX | STRIX ROG 1060 OC 6G | EVGA G2 650W | ROSEWILL B2 SPIRIT | SANDISK 256GB M2 | 4x 1TB Seagate Barracudas RAID 10 ]
[i3-4360 | mini-itx potato | 4gb DDR3-1600 | 8tb wd red | 250gb seagate| Debian 9 ]
[Dell Inspiron 15 5567]
15 minutes ago, Wasard said:
http://www.speedtest.net/result/5198206874.png
I live like 4 miles from the exchange and my internet is unbearably bad is there anyway I can improve it without moving closer to the exchange?
If you want faster speeds, you'll need to pay for an upgraded plan from your ISP. Otherwise you are limited to the amount your ISP says you can have.
by looking at your speedtest results , your isp seems to be bt global services, do you have any bills from them?
here is their site:
http://www.globalservices.bt.com/uk/en/home
if i post a link to amazon try to use the LTT affiliate code to help the channel http://www.amazon.com/?_encoding=UTF8&camp=1789&creative=390957&linkCode=ur2&tag=linustechtips-20
How do I know what plan I have? I asked my parents what we have and all they said was 'unlimited broadband'
Look at the bill
The plan should list the speed you get for the "unlimited broadband". It is listed as an mbps.
On their site it lists that plan as having "upto" 17mbps.
The site said up to 17mb. But I don't have even a fraction of that.
unlimited broadband just means you can access unlimited data with no overage charge(as in gigabytes, terabytes, etc), its doesnt apply to the speed, though if you are getting that kind of speed i wouldnt call that "broadband"
key words are up to. Meaning the company can give you anything less. You might be better off switching providers or upgrading your plan in this case. There's no setting changes you can make to your networking setup to improve this speed.
Well if you look at that graph I linked in they are talking about people <3km getting ~17mbps.
If you want more speed but are ok with datacaps (overages potentially as well, be careful on that bit) 4G potentially could be much faster and if your willing to mount an antenna to your roof you can probably get excellent signal even if your very far from the cell tower.
