Can anyone tell why my computer lags significantly after 5-10 minutes of online multiplayer game play, it was working fine a few weeks ago, and i haven't change or upgrade anything. My temp while gaming are; CPU 55c and GPU 70c. I have downgraded from Win10 to Win7 but it's the same issue
Specification:
Motherboard - MSI 970 Gaming
CPU - AMD FX6100 (stock cooler, not overclock)
GPU - MSI r9 270 2gb vram
RAM - G.SKILL Ripjaws Series 8GB (2 x 4GB) OC to 1866mhz
Case - Rosewill Blackhawk Gaming ATX mid tower
Storage - Ocz vertex 2 120gb(SSD) and WD blue 620gb
PSU - Corsair CX 430
https://linustechtips.com/topic/568738-help-please/
Are you sure it is not your internet or the server's connection? That seems the most likely IMO
https://linustechtips.com/topic/568738-help-please/#findComment-7465995
if he is getting low fps then its probably not a connection problem. if he is lagging but has regular fps it is a connection problem
https://linustechtips.com/topic/568738-help-please/#findComment-7466038
