I got a pump water pump question : )
Solved by blu4,
You chose the tubing size for the fittings you will use, not for the actual water blocks. I have got 3/16' I believe and I managed to get that on 1/2' pump. Dip the tube in very warm water for 15 seconds and stretch it over the pump nozzle.
This is what a fitting looks like, chose tubing according to the size of it.
http://i.kinja-img.com/gawker-media/image/upload/s--x-1RyNNE--/17y2tmzlvcjo1jpg.jpg
