"A USB 2.0 to USB 3.2 Gen 1 header adapter is required." and " USB 3.2 Gen 1 to USB 3.2 Gen 2 header adapter." Note in PcPartPicker.
Go to solution Solved by Poinkachu,
12 minutes ago, daffaqua said:
Okay so,
Blue circle - the USB-C port on my case
Red circle - the other end that I plug into MB to actually make the USB-C port work
Yep
I'm picking out parts for my first pc build, and when I think I'm done, PcPartPicker gives me a note that says I need adapters for some USB on my motherboard.
Can someone link the adapters I need on Amazon, and explain to me what this means?
Build link: https://pcpartpicker.com/list/Ny7YDZ
Build link: https://pcpartpicker.com/user/LVUP/saved/tKnGjX
That pcpartpicker list is private
Refresh before you reply
Posted (edited)
17 minutes ago, daffaqua said:
Basically :
- Your motherboard doesn't have an internal USB-C header, while the PC Case has a Type-C front port.
This made PCpartpicker system throws out those "warning"
So your options are :
1. Leave the front Type-C port unused. No Adapter(s) needed.
2. Buy a USB3 header to Type-E adapter. This makes your type-c port usable, but the two Type-A USB3 port unusable.
Example : https://www.amazon.com/LUORNG-Motherboard-Integrated-Connector-Extension/dp/B0D2KSJQCW/
3. Buy a USB3 header to Type-E adapter, and a USB2 header to USB3 header adapter.
- This makes your type-c port usable as USB3, and your 2x Type-A USB3 works as Type-A USB2 ports.
Example of USB2 header to USB3 header adapter : https://www.amazon.com/Duttek-2-pack-Motherboard-Adapter-Converter/dp/B072ZV1566/
edit:
- Or the #3 alternatively can also be used in a way that makes your Type-C port work as Type-C USB2 port, and your Type-A USB3 ports as USB3, as @-rascal- said below.
Edited by Poinkachu
Ahhh...
The motherboard does not have an internal USB-C header, so PCPartPicker is telling you to convert:
USB 2.0 header -> USB 3.0 Adapter -> USB-C Adapter
You don't have to do that...you just can't use the Front Panel USB-C that's on the case.
The motherboard has a USB 3.0 header for the 2x front USB 3.0 ports, though
(AKA USB 3.2 Gen 1)
Your other option is to pick another B550 / X570 motherboard that HAS a USB-C Header.
I'm assuming you NEED the built-in WiFi / Bluetooth?
If you want to stick with ASUS ROG... ROG STRIX-XE Gaming has it.
https://pcpartpicker.com/product/zfMTwP/asus-strix-b550-xe-gaming-wifi-atx-am4-motherboard-strix-b550-xe-gaming-wifi
If you don't mind switching motherboard brands....
Gigabyte B550 Arous Elite AX V2
https://pcpartpicker.com/product/Vb3mP6/gigabyte-b550-aorus-elite-ax-v2-atx-am4-motherboard-b550aorus-elite-axv2
MSi MAG B550 Tomahawk Max WiFi
https://pcpartpicker.com/product/MfZ9TW/msi-mag-b550-tomahawk-max-wifi-atx-am4-motherboard-mag-b550-tomahawk-max-wifi
AsRock X570 Taichi
https://pcpartpicker.com/product/pbvqqs/asrock-x570-taichi-atx-am4-motherboard-x570-taichi
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Also, recheck your cooler and your RAM clearance.
From a glance I've given to both, they will interfere unless you position the cooler's fan more upward
If you are okay with that, all good.
15 minutes ago, Poinkachu said:
Basically :
edit:
I'm still a bit confused... do you think you could elaborate a little bit more?
Sure. on which part ?
When you said "Buy a USB3 header to Type-E adapter, and a USB2 header to USB3 header adapter."
I want to make all the ports on my case work.
I am so very new to PC building, so if you could also simplify it a bit, I'd appreciate that.
 I am guessing you want me to elaborate on where to use the adapters ??.
So you plug this one to your motherboard's USB3 header [refer to pic below], then you plug the Type-C connector from your case to the adapter.
And then you plug this one to one of your motherboard's USB2 header [refer to pic below], then you plug the USB3 connector from your case to the adapter.
But honestly speaking. That way you will end up with a Type-C port that has 5Gbps speed, and 2 type-A ports that has 480Mbps speed.
The only good thing about it is if you REALLY REALLY need a high speed Type-C port at the front of your PC case.
Lemme know if there's other explanation you want.
USB2 Headers Location
Page 1-14 of the motherboard's manual
USB3 header location
Page 1-13 of the motherboard's manual
The only way to use both (front Type-C and 2x Front Type-A) at their intended speed is either :
1. Change motherboard to one that has Type-C header
Example : One of what @-rascal- linked above.
or
2. Use a PCIE addon card
Example : https://www.amazon.com/BEYIMEI-Expansion-Internal-Connector-Express/dp/B0B156WMGC/
Posted (edited)
  Reveal hidden contents
or
Thank you, I'm starting to understand a bit more now, but there's still some things I don't understand.
When you say Type E and USB2 & USB3, what are you referring to?? I have absolutely zero experience with this sort of thing so I would not know.
Edit: I've just settled on choosing a different MB, but I would still like to be informed for future reference.
Edited by daffaqua
Type-C header on the motherboard, and the connector that goes into it often called Type-E by adapter manufacturers
USb 2 header on motherboard, often called USB2 9pin header too.
USB2 9pin connector
USB3 header on motherboard, often called USB3 19pin too
USB3 19pin connector
USB Type-C port and connector :
USB Type-A port and connector :
USB Protocol generation :
https://www.photometrics.com/learn/imaging-topics/usb-through-the-ages
USB2 9pin connector
So, the Type-E connector is what enables me to use the USB-C on my case?
The Type-E is just the shape and pinout of the connector.
What actually makes it usable is the microcontroller chip on the motherboard.
Okay, so the Type-E connector is what's attached to the case
For the type-c port yeah.
This is pretty much what it looks like in entirety (Minus the steel bracket)
This is pretty much what it looks like (Minus the steel bracket)
Okay so,
Okay so,
Yep
Yep
Thank you so much for your help!
