Posted March 10, 2016 I really like the mITX cases available these days (Phanteks Enthoo ITX) and my new gaming rig will be single GPU and air cooled. mITX boards have fewer power phases though, so are they suitable for a decent (nothing extreme) overclock on an i5-6600k? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2016 yes If it's not an exteme OC, it'l be just fine on an mITX board Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+ Smallsnor: Huawei Matebook X Canon AE-1 w/ 50mm f/1.8 lens Pentax KM w/ 55mm f/1.8 SMC lens Zenit-E w/ 58mm f/2 Helios lens Panasonic G7 with 14-42mm f/3.5 lens Polaroid Spectra System Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2016 Yeah they are. If you want extreme though, you should look into the Impact series from Asus. They have an extended VRM board. Gaming HTPC: R5 5600X - Cryorig C7 - Asus ROG B350-i - EVGA RTX2060KO - 16gb G.Skill Ripjaws V 3333mhz - Corsair SF450 - 500gb 960 EVO - LianLi TU100B Desktop PC: R9 3900X - Peerless Assassin 120 SE - Asus Prime X570 Pro - Powercolor 7900XT - 32gb LPX 3200mhz - Corsair SF750 Platinum - 1TB WD SN850X - CoolerMaster NR200 White - Gigabyte M27Q-SA - Corsair K70 Rapidfire - Logitech MX518 Legendary - HyperXCloud Alpha wireless Boss-NAS [Build Log]: R5 2400G - Noctua NH-D14 - Asus Prime X370-Pro - 16gb G.Skill Aegis 3000mhz - Seasonic Focus Platinum 550W - Fractal Design R5 - 250gb 970 Evo (OS) - 2x500gb 860 Evo (Raid0) - 6x4TB WD Red (RaidZ2) Synology-NAS: DS920+ 2x4TB Ironwolf - 1x18TB Seagate Exos X20 Audio Gear: Hifiman HE-400i - Kennerton Magister - Beyerdynamic DT880 250Ohm - AKG K7XX - Fostex TH-X00 - O2 Amp/DAC Combo - Klipsch RP280F - Klipsch RP160M - Klipsch RP440C - Yamaha RX-V479 Reviews and Stuff: GTX 780 DCU2 // 8600GTS // Hifiman HE-400i // Kennerton Magister Folding all the Proteins! // Boincerino Useful Links: Do you need an AMP/DAC? // Recommended Audio Gear // PSU Tier List Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2016 I can't overclock my 7850k on one of the highest end mITX mother boards for FM2+. So I don't know, it may be different. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2016 2 minutes ago, mhonor said: I really like the mITX cases available these days (Phanteks Enthoo ITX) and my new gaming rig will be single GPU and air cooled. mITX boards have fewer power phases though, so are they suitable for a decent (nothing extreme) overclock on an i5-6600k? Depend on the board there are some very nice mITX overclocking capable boards like this, pricey though: http://www.anandtech.com/show/9854/asus-maximus-viii-impact-z170-rog-review-itx Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2016 Author Just now, W-L said: Depend on the board there are some very nice mITX overclocking capable boards like this, pricey though: http://www.anandtech.com/show/9854/asus-maximus-viii-impact-z170-rog-review-itx I want to stay below $150. ASRock's two Z170 motherboards have 6 and 8 power phases and all the features I would need. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2016 This video may be of help, for fairly standard overclocks you shouldn't notice much difference. CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Link: http://nz.pcpartpicker.com/list/hPjFd6 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2016 Author 6 minutes ago, Str_Mape said: This video may be of help, for fairly standard overclocks you shouldn't notice much difference. Thanks - ya I've seen that and I am definitely not interested in a premium board. I've just heard that power phases are important for overclocking and often overlooked, so I thought I'd ask the forum. Is anybody using a mid-range ITX board with a k series CPU? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2016 10 minutes ago, mhonor said: I want to stay below $150. ASRock's two Z170 motherboards have 6 and 8 power phases and all the features I would need. More power phases can help with stable power if your really pushing things but stands out usually for very high voltages, most of the mitx ones like theses would be very capable of getting pretty good overclocks: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157650 http://www.newegg.com/Product/Product.aspx?Item=N82E16813132641 http://www.newegg.com/Product/Product.aspx?Item=N82E16813130880 Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 10, 2016 Author 9 minutes ago, W-L said: More power phases can help with stable power if your really pushing things but stands out usually for very high voltages, most of the mitx ones like theses would be very capable of getting pretty good overclocks: Thanks! I've checked those out and like the ASRock a lot. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 11, 2016 Depending on ITX case size and cooler height support... there will be options like the Asus Maximus VIII Impact Spartan 1.0 Spoiler CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor CPU Cooler: Cooler Master Seidon 120XL 86.2 CFM Liquid CPU Cooler Motherboard: Asus Maximus VI Extreme ATX LGA1150 MotherboardMemory: Corsair Dominator 32GB (4 x 8GB) DDR3-1600 MemoryStorage: OCZ Vector Series 512GB 2.5" Solid State DriveStorage: Seagate Desktop HDD 4TB 3.5" 7200RPM Internal Hard Drive Video Card: EVGA GeForce GTX 980 4GB Classified ACX 2.0 Video CardCase: Thermaltake Urban S41 ATX Mid Tower CasePower Supply: Corsair 1200W 80+ Platinum Certified Fully-Modular ATX Power SupplyOptical Drive: LG BH16NS40 Blu-Ray/DVD/CD WriterOptical Drive: LG BH10LS30 Blu-Ray/DVD/CD WriterOperating System: Microsoft Windows 10 Pro 64-bitSound Card: Creative Labs ZXR 24-bit 192 KHz Sound CardMonitor: 2x Asus VG278HE 27.0" 144Hz MonitorKeyboard: Logitech G19s Wired Gaming KeyboardKeyboard: Razer Orbweaver Elite Mechanical Gaming Keypad Wired Gaming KeyboardMouse: Logitech G700s Wireless Laser MouseHeadphones: Creative Labs EVO ZxR 7.1 Channel HeadsetSpeakers: Creative Labs GigaWorks T40 Series II 32W 2ch Speakers Hades 1.0 Spoiler Laptop: Dell Alienware 15 2015 CPU: i7-4720HQ CPU Memory: 16GB DDR3 SODIMM RAM Storage: 256GB M.2 SSD Storage: 1TB 5400rpm 2.5" HDD Screen: 15.6" FHD Display Video Card: Nvidia GTX 970M with 3GB Operating System: Windows 10 Pro Project: Spartan 1.2 PLEASE SUPPORT ME NEW CHANNEL > Tech Inquisition Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
