Corsair H100i GTX Pump Cable
Solved by W-L,
11 minutes ago, cclau said:My Corsiar H100i GTX works just fine and I'm happy that I bought it. The only thing that I don't like about it is that the cable for the pump is angled left, away from any of the rubber grommets for cable management. If anyone has a solution they can think of that can fix this, it would be appreciated, or if anyone knows where I can get my hands on one of the cables for the H100i GTX that is angled to the right, that would be even better. (top is mine, bottom is what I would want.)
The most common way to run the USB data cable I see if to have it go along the side of the block and up the top behind the motherboard before going back to a USB connection.
