Hey,
I am looking forward to the release of the PG348Q and upcoming lines of GPU from either sides. Since this monitor has a Gsync module, I was wondering if it was possible for a manufacturer to make a gsync monitor support freesync as well. I never saw that being in the works or even talked about. Is this one of these cases of manufacturers having annouced support for X, so they won't support competing Y ?
This has probably been answered a few times. I'm sorry if so.
Regards
https://linustechtips.com/topic/545847-both-gsync-and-freesync/
6 minutes ago, Virgule said:
Hey,
Regards
monitors don't support both free- and gsync at the same time, but the manufacturer can make 2 versions, a free- and a gsync version :)
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7217971
I don't think they do as GSync is a propriety controller so they won't support free sync.
See my Build here!
Intel 6700k -  Strix GTX 1080Ti - Corsair AX760 - Corsair Dominator 16GB 3000MHz - ASUS Maximus VIII Hero
Seagate Barracuda 1TB -  Samsung 120GB 840 - Samsung 840 EVO 250GB - Corsair H100i - Corsair Air 540 White -
Corsair AF120 - 2x Noctua NF-F12 - 3 x Noctua NF-S12
 Dell S2417DG - Dell UH2515H
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7217977
7 minutes ago, Virgule said:
Hey,
Regards
Nope not possible yet. However one thing is: Freesync doesn't require any modules so NVidia could drop their gsync support and take up freesync, however it wouldn't work on current/past cards. Chances of that happening? slim they still use PhysX ...
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7217978
i doubt nvidia will let monitor manufactures "install" freesync on gsync monitors as they pretty much control and approve gsync monitors. where as anyone can slap freesync into a monitor amd does not officially approve the monitors. that being said i prefer gsync as it more tightly controlled and has a higher chance of not having as many issues as freesync because nvidia approves the monitors.
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7217982
From what you guys respond, what I understand is more "manufacturers don't make monitors that support both and they can't because they currently don't".
This doesn't explain why they can't. I know Gsync needs a dedicated modules that is licensed by NVidia. The fact that freesync don't makes it possible in my mind (discarding marketing reasons) to manufacture a monitor that supports both, may it be via a dual bios or whatever else.
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218013
12 minutes ago, Virgule said:
Hey,
Regards
SUre why not but that would defeat Nvidia's real purpose and that keep people buying Nvidia. They could add freesync support to there cards real easy that way Nvidia fans could use a g-sync or freesync monitor.
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218034
Just now, NoobCase said:
Moneyz that's why...
On the contrary ! Pannel manufacturers would MAKE money offering pannels that support both standards. Sure, there's a bit needed R&D but they already make both, so doesn't seem to be a far stretch.
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218097
24 minutes ago, Virgule said:
Hey,
Regards
On 6/21/2015 at 8:16 PM, Glenwing said:
There may be one or two in the future, but it's only going to be as a "just to say we did" kind of product. At least with the current G-SYNC module, the only way to do this would be to have two display controllers, the G-SYNC module and a standard controller chip, which would make the monitor exorbitantly expensive, even more expensive than a regular G-SYNC monitor. In addition, it would have to have dedicated inputs for each controller, meaning a DisplayPort input which can only be used for G-SYNC, and another DisplayPort input which can only be used for FreeSync. There are plenty of other design challenges involved too, such as software and features... these would not be shared between the controllers. The monitor would only be able to use ULMB (for example) if you hook your computer to the DisplayPort input connected to the G-SYNC module, not the other DisplayPort inputs. And likewise for any additional features from the monitor vendor which are not included in the G-SYNC module by NVIDIA.
There's not much practical purpose or market for such a monitor either, because it would end up being more expensive than either a G-SYNC or FreeSync standalone monitor, and no one is really going to use both. Either you need G-SYNC, in which case you don't care about FreeSync and might as well get a G-SYNC-only monitor for less money, or you need FreeSync, in which case you might as well just get a FreeSync-only monitor for significantly less, and you won't miss G-SYNC. The only person that might want a monitor with both is someone who wants to "future-proof" as much as possible, and wants a monitor that can be used with both so that it doesn't restrict their future GPU upgrade choices.
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218108
Nvidia Moneyz....  So still the answer
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218135
Hallelujah !! @Glenwing with the knowledge saves the day as always.
Exactly my case and why I'm asking......:(
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218152
I think there are lots of people who would like the idea of a monitor that supports both, but few willing to pay the price if they knew what it would cost. Sure there are some, but not enough for interest from monitor companies. It's often forgotten that even though FreeSync and G-Sync are popular subjects in the forums and places we visit, in the grand scheme we only represent a small percentage of the market, most of the public, even most of the "gamer" market, does not even know these features exist, or care about expensive monitors, anything that says "1080p LED" is enough. And only a small percentage of that small percentage of the market would be willing to pay the price for both, which is a very small number of people.
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218249
As I already said, the easiest way would be for Nvidia to dump Gsync and utilise Freesync, however that proprietary tech not only nets them money in sales of the gsync module, but it also keeps people tied to NVidia. On the flipside, Freesync, whilst it doesn't cost AMD for it to be used physically, it does keep freesync users tied to AMD. Now, this is where I think Nvidia are cutting their own hands off. Yes they keep people tied to Nvidia, however, people may not move over from AMD cause they wont pay the Gsync premium....
Ryzen Ram Guide
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218341
I totally agree @Glenwing. With just about everything computer related, we represent a small margin of the market willing to shell out lots of cash for expensive monitors with features that nobody knows existed. I also believe we also represent the most informed as well since we exchange lots and lots of information every hour, because in the grand scheme of things, the vast majority of the market are ill-informed (not to insult, but it's true.)
RIGZ
Starlight (Current): AMD Ryzen 9 3900X 12-core CPU | EVGA GeForce RTX 2080 Ti Black Edition | Gigabyte X570 Aorus Ultra | Full Custom Loop | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 1TB + 2TB M.2 NVMe PCIe 4.0 SSDs, 480GB SATA 2.5" SSD, 8TB 7200 RPM NAS HDD | EVGA NU Audio | Corsair 900D | Corsair AX1200i | Corsair ML120 2-pack 5x + ML140 2-pack
The Storm (Retired): Intel Core i7-5930K | Asus ROG STRIX GeForce GTX 1080 Ti | Asus ROG RAMPAGE V EDITION 10 | EKWB EK-KIT P360 with Hardware Labs Black Ice SR2 Multiport 480 | 32GB (4x8GB) Dominator Platinum SE Blackout #338/500 | 480GB SATA 2.5" SSD + 3TB 5400 RPM NAS HDD + 8TB 7200 RPM NAS HDD | Corsair 900D | Corsair AX1200i + Black/Blue CableMod cables | Corsair ML120 2-pack 2x + NB-BlackSilentPro PL-2 x3
STRONK COOLZ 9000
EK-Quantum Momentum X570 Aorus Master monoblock | EK-FC RTX 2080 + Ti Classic RGB Waterblock and Backplate | EK-XRES 140 D5 PWM Pump/Res Combo | 2x Hardware Labs Black Ice SR2 480 MP and 1x SR2 240 MP | 10X Corsair ML120 PWM fans | A mixture of EK-KIT fittings and EK-Torque STC fittings and adapters | Mayhems 10/13mm clear tubing | Mayhems X1 Eco UV Blue coolant | Bitspower G1/4 Temperature Probe Fitting
DESK TOIS
Glorious Modular Mechanical Keyboard | Glorious Model D Featherweight Mouse | 2x BenQ PD3200Q 32" 1440p IPS displays + BenQ BL3200PT 32" 1440p VA display | Mackie ProFX10v3 USB Mixer + Marantz MPM-1000 Mic | Sennheiser HD 598 SE Headphones | 2x ADAM Audio T5V 5" Powered Studio Monitors + ADAM Audio T10S Powered Studio Subwoofer | Logitech G920 Driving Force Steering Wheel and Pedal Kit + Driving Force Shifter | Logitech C922x 720p 60FPS Webcam | Xbox One Wireless Controller
QUOTES
"So because they didn't give you the results you want, they're biased? You realize that makes you biased, right?" - @App4that
"Brand loyalty/fanboyism is stupid." - Unknown person on these forums
"Assuming kills" - @Moondrelor
"That's not to say that Nvidia is always better, or that AMD isn't worth owning. But the fact remains that this forum is AMD biased." - @App4that
"I'd imagine there's exceptions to this trend - but just going on mine and my acquaintances' purchase history, we've found that budget cards often require you to turn off certain features to get slick performance, even though those technologies are previous gen and should be having a negligible impact" - ace42
"2K" is not 2560 x 1440
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218365
Yes but freesync is virtually no extra cost to manufacturers so if Nvidia supported both then more people would get a better experience because of freesync's lower cost. There are 2 major players that make panels Samsung and LG and neither make a g-sync panel but they do make a freesync version and sell it under there name. Manufactures make the majority of their money selling volume not specialty monitors.They let the ASUS and such of the world buy their panels and pay Nvidia the $250 extra to use their special gizmo and worry about selling the low volume item. I can see freesync being just that on every non g-sync in the future. You can buy a freesync from $150 to 1200 panels where Nvidia's cheapest starts at at $400 on new egg up to 1300.
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218405
Yes, but that's not something monitor manufacturers can decide. As it stands for now, and for the foreseeable future, if a monitor vendor wants to implement both FreeSync and the current G-Sync implementation today they would have to do it with separate controllers.
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218413
As much as I want that to happen for the sake of standardization, I have come a long way and accepted that G-sync is to this day somewhat "better" than Freesync on the grounds of low FPS cut and ghosting. I REALLY like the idea of Freesync being, well free, and not needing additional licensed hardware but at this point, I just want the best panels to support the better features, with a preference for all of the features of course.
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218429
OH ya no doubt they could include both controllers and whichever is detected by the GPU it will switch to and use. Just the extra cost to do that not sure why. Sounds like this guy has a Nvidia card and does not want to pay for a g-sync or wants options for the futre
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218447
I agree, I have a Gsync RoG (well spiritually its away for RMA) and I loved my brief experience with it. Just feels like Nvidia is crippling the market with it when everyone could use Freesync and flip and change between AMD/Nv as they see fit. But then again, Nvidia crippling the market is nothing new, take Gameworks for example...
And this is coming from me with 2x 970 and a Gsync monitor lol
Ryzen Ram Guide
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218459
http://www.lg.com/us/monitors/lg-34UC98-W-ultrawide-monitor
Just ordered mine today. Now I can decide if I like my 27um67-b or this 34" better.
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218468
Honestly I think also Nvidia tries to push Asus and others that make there g-sync to go to high on the refresh rates and I see a lot o people complaining. Then the same panels used on a freesync are less refresh rates and I see a lot less complaints. I think they are trying to push panels to do more than they are designed for.
http://www.lg.com/us/monitors/lg-34UC98-W-ultrawide-monitor   Will let ya know mine will be here tommorow
https://linustechtips.com/topic/545847-both-gsync-and-freesync/#findComment-7218508
