Chromebook Battery Packs
Go to solution Solved by Bananasplit_00,
1 minute ago, George Cristea said:
ill try without battery to see whats going to happen.  I mean the thing was because its density increased... I didn't want to have some problems with the freaking battery exploding ... ( I know I have good imaginary reactions but still ... I am never sure of what can happen with a battery ... still a battery - I don't know how it reacts.).
should be fine without the battery as long as you power down before pulling the cord, and go put that battery somewere safe, like NOW
Samsung Chromebooks work without battery packs ?
You know usually, the laptops if you remove the battery, you can still use it if the battery is dead... (is removed) if it is pluged to a socket... how about chrome books.. if I remove the battery  ? :/
Thank you In advance.
if it has no power, it will not work
it will have power, ill use the cable power,, but not the battery, so unless I unplug it ... it should work .. shoudnt it ?:/
unless samsung made the worst power delivery system ever, which i doubt
What might be the worst case scenario... not to work isn't it ? ;/ like... nothing else..
well
yeah
my laptop has it so you have to have the battery plugged in for it to work lol
Builds:
wait
seriously?
this was a problem fixed in 2001
or earlier
thats
what the fuck?
wait
seriously?
or earlier
thats
what the fuck?
Pavilion G6 from 2013, battery is looooooong gone and its kind of a pain but yah it has this problem
Builds:
if the battery isnt in the laptop, it wont work?
no don't get it mate, I do have a battery in the chromebook but it kinda become big for too much charging .. since it didn't want to work without the cable... the battery was charged but didn't want to power on if the cable wasn't in... so idk what to do .. the battery keeps getting bigger and bigger.. so I don't want to replace it since is a chromebook that idont ususaly use  but still I don't want to throw it yet.
Was just wondering if I can use it without the battery in ... but with the cable power inside it.. like getting power from the cable... because on laptops you can do it .. but not sure about chromebooks
yup, thats exactly it
wait.. the battery itself is getting bigger? THAT IS REALLY FREAKING BAD MAN OMFG, that could explode in a fireball if not delt with properly....
Builds:
i didnt notice that
yeah
take that bettery out NOW AND DO NOT TOUCH IT
IF YOU HAVE SOMETHING FIREPROOF, PUT IT IN THERE
Builds:
hold on
is it the same size, or are the dimensions increased
don't worry .. the chromebook is not powered while I'm doing this... but where should I place the battery after removing it ? ;/
dimension increased...
take it out
do not use that battery
do not mess with it
get a new one
dispose of that one properly
4 minutes ago, Josephdalepi said:
take it out
do not mess with it
get a new one
by disposing .. what do you actually mean ... where to put it.
it actually uses same principles as a laptop.. still works without the battery and with the power cable in ... that's good. thanks for your assistance anyway ;)
Both of you
look it up for your area
hazardous waste management is what your looking for
