Posted February 6, 2016 Hello, I would really appreciate some feedback on my build. I below have a list of all the parts, keyboard, mouse, monitors etc. I would like to know if everyone agrees with my build and everything should run and fit properly. If you have i any suggestions on better parts or quick add one, please let me know. Case: Corsair CC-9011048-WW Carbide Series Air 540 Windowed ATX High Airflow Cube Performance Computer Case with White LED Fan - Arctic White Motherboard: ASUS ATX DDR4 3000 LGA 2011-3 Motherboards X99-DELUXE/U3.1 CPU: Intel Core i7-5820K Haswell-E 6-Core 3.3GHz LGA 2011-v3 140W Desktop Processor BX80648I75820K CPU Cooler: Corsair Hydro Series H115i Extreme Performance Liquid CPU Cooler Cooling CW-9060027-WW I plan on mounting the 280mm H115i to the top of my case and pushing air out of the top. Also will have hose go around towards the front. GPU: MSI Computer PCI-Express Video Card GTX 980TI SEA HAWK I plan on mounting the H55 attached to GPU to the rear 120mm fan mount. I would love to know if this will work and fit with my 280mm on top. RAM: Corsair Dominator Platinum Series 16GB DDR4 DRAM 3000MHz C15 Memory Kit for Systems 3000 MT/s CMD16GX4M2B3000C15 Power Supply: Corsair HXi Series, HX1000i, 1000 Watt (1000W), Fully Modular Power Supply, 80+ Platinum Certified OS: Windows 10 64bit Boot Drive: Intel 80 GB 530 Series SATA M.2 0.85-Inch Solid State Drive (Drive only) SSDSCKGW080A401 SSD: Samsung 850 EVO 250GB 2.5-Inch SATA III Internal SSD (MZ-75E250B/AM) SSHD: Seagate 1TB Desktop SSHD(Solid State Hybrid Drive) SATA 6Gb/s 64MB Cache 3.5-Inch Internal Bare Drive (ST1000DX001) Monitor x2: Asus VG248QE 24-inch Full HD Ergonomic Back-lit LED Gaming Monitor Keyboard: Corsair Gaming K70 Mechanical Gaming Keyboard, Aircraft-Grade Aluminum (CH-9000117-NA) Mouse: Logitech G303 Daedalus Apex Performance Edition Gaming Mouse (910-004380) I do not plan on playing games 24/7 so I am not going for an intense gaming mouse or keyboard. I did also get a mouse pad and thermal paste but did not list it. Pretty straight forward. I am using th 80GB drive for booting my OS. My SSD is for main important programs and games. SSHD is general. I will eventually get more ram. For now I only need 16GB. I will use this system for development, photos, videos, games, renendering etc. I need an all around machine and I would like for it to last 10 years with minimal upgrades. I will be using DisplayPort of course and how to have a powerful, stable and beastly machine. Thank you for the help. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 6, 2016 Overkill RAM ... you could get cheaper one with same speed, 850 is enough for two 980ti in SLI if the price on 1000watts psu is good go get it. You might want to get larger Hard drive for you projects/backup. Magical Pineapples
