Posted February 1, 2016 What would you recommend someone on a budget? The dual core Pentium or the quad core athlon? Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 The dual core will likely perform better in most games. But I have heard of games that wont even start on a dual core. If you can pick up an fx-6300 or something and overclock it, that might be an even better option. For example: http://www.pcworld.com/article/2851126/far-cry-4-woes-with-dual-core-processors-point-to-a-bleak-future-for-budget-pc-gamers.html EDIT: Pickup a low end quad core i5 if you can http://m.newegg.com/Product/index?itemnumber=N82E16819116781 PC: 9800X3D, 96GB Trident Z5 6200 CL28, 5090 FE, 3.84TB CM7 NAS: Xeon W-2195, 256GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141730 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 Quad core. USEFUL LINKS: PSU Tier List | F@H stats Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141734 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 Neither. An i3 setup if you can hack it. my work in progress i5 6600k // 16gb g.skill ddr4 3000 // evga gtx 980 custom water loop Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141742 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 If you want a clear upgrade path to a better chip (potentially much better, like, Xeon 1231v3 or i7-4770K/4790K better), get the Pentium. If you don't care about having an upgrade path and just want something to handle today's games at playable FPS, grab the Athlon. I enjoy buying junk and sinking more money than it's worth into it to make it less junk. Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141782 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 860k is better than pentium. 8 minutes ago, ChronicGenocide said: The dual core will likely perform better in most games. But I have heard of games that wont even start on a dual core. If you can pick up an fx-6300 or something and overclock it, that might be an even better option. For example: http://www.pcworld.com/article/2851126/far-cry-4-woes-with-dual-core-processors-point-to-a-bleak-future-for-budget-pc-gamers.html FX6300 is beyond outdated. i3 6100 would be ideal. Location: Kaunas, Lithuania, Europe, Earth, Solar System, Local Interstellar Cloud, Local Bubble, Gould Belt, Orion Arm, Milky Way, Milky Way subgroup, Local Group, Virgo Supercluster, Laniakea, Pisces–Cetus Supercluster Complex, Observable universe, Universe. Spoiler 12700, B660M Mortar DDR4, 32GB 3200C16 Viper Steel, 2TB SN570, EVGA Supernova G6 850W, be quiet! 500FX, EVGA 3070Ti FTW3 Ultra. Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141784 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 Well whats your budget? Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141785 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 i3-6100 | CPU: Core i7-8700K @ 4.89ghz - 1.21v | Motherboard: Asus ROG STRIX Z370-E GAMING | CPU Cooler: Corsair H100i V2 | | GPU: MSI RTX 3080Ti Ventus 3X OC | RAM: 32GB T-Force Delta RGB 3066mhz | | Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141790 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 Author 1 minute ago, 3DGamerOnSteam said: Well whats your budget? Not a lot lol, like 450 or something, otherwise you would want something else Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141798 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 Author 2 minutes ago, ZetZet said: FX6300 is beyond outdated. i3 6100 would be ideal. wow, *Tears up* You hurt my 4 year old CPUs feelings Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141803 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 1 minute ago, Mohenjo said: Not a lot lol, like 450 or something, otherwise you would want something else Have you got any of the parts yet? Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141806 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 Author 1 minute ago, 3DGamerOnSteam said: Have you got any of the parts yet? oh, im not building anything. This is just a poll Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141819 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 1, 2016 860K is a better CPU overall, however if you're going to upgrade sooner than around 6 months, go with the pentium CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White Link to comment https://linustechtips.com/topic/538970-g3258-vs-860k/#findComment-7141877 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
