Need Help! I can not seem to choose which motherboard to go with!
Solved by Imakuni,
Ok I don't know what power phases are or where to look for them.
To sum it up, it represents how spread out is the power delivery to your CPU. Fewer phases means fewer components providing power, and thus more stress and less stability, to a certain extent. Basically, the more the "better".
Using the Asus Z170a as an example, look around the socket area. See those squares lined up on the right? Count how many are there (in this case, 10). Being a little rough, that's the number of power phases. Ofc, it isn't totally as plain as I made it sound, but it's already a good enough filter.
Or you could look for a review online that states the number of phases, though you won't find that for every mobo around.
