Posted January 28, 2016 So I was playing some league of legends and out of nowhere my internet cuts out. This is this second cat 6 cable that this has happened too it just stops working I plugged it into my ps4 to make sure it isn't my computer port but it didn't work in there either. I don't know why this is happening or what is causing it. Could it be my router please help. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2016 Why do you need a CAT6 Cable? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2016 Did you buy cheap cables? Usually it is almost impossible for them to break. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2016 Author It's is all that I can find at my local stores and it's all that I have in My house. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2016 Author Did you buy cheap cables? Usually it is almost impossible for them to break. kind of I mean it isn't the cheapest one ever. I'm getting ready to buy a new one any suggestions need at least a 50 footer buying off Amazon. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2016 Well CAT6 is only like 50 cent difference from CAT5E so i was like why not. Just buy one it really cheap ... around one dollar for one, maybe change your buyer/seller. Magical Pineapples
